Cric Info Stats Pages
    deakmann
    Posts: 9 from 2009/11/24
    I`ve just noticed that OWB makes somewhat of a hash displaying the stats pages on cricinfo.com. It looks likes its being displayed by a non css browser.
    Any idea what the problem is?
    http://stats.cricinfo.com/ci/engine/current/records/index.html?id=2009;type=year
  • »30.12.09 - 15:07
    stephen_robinson
    Posts: 746 from 2007/4/22
    I can confirm it looks wrong on OWB MorphOS, looks fine on Amiga 4.1 OS's OWB 3.22.
    Is that any help? :-)
    [ Edited by stephen_robinson on 2009/12/30 18:00 ]
  • »30.12.09 - 15:59
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    It's displayed just fine, but the explanation is you probably have content blocker enabled, and this site URL triggers one of the default rules, which prevents from loading resources, hence the ugly look.
    So just find the offending rule in the content blocking window, or disable content blocking, at worst. :)
  • »30.12.09 - 16:46
    deakmann
    Thanks Fab, yes the content blocking was the offender here, I had to test each blocked line manually until I found the one responsible.
    Thanks again.
  • »30.12.09 - 18:39
    Krashan
    Posts: 1107 from 2003/6/11
    What is funny, default adblock rules block all images and stylesheets from distributed.net pages. I haven't found yet, which rule is responsible for this.
    [ Edited by Krashan on 2009/12/31 6:57 ]
  • »31.12.09 - 04:57
    roschmyr
    Posts: 211 from 2003/2/20
    as a temporary solution, i have added the rule Allow http://stats.distributed.net/* to the Content Blocking. Works for me (TM)  8-)
  • »31.12.09 - 08:02
