Manual reinstall of MorphOS 2.5 with existing Mac OS
    osco
    Posts: 680 from 2009/10/20
    I have retail Leopard install disk..
    I would like to reinstall MorphO2.4
    A dual boot with MorphOS the priority.
    Four partitions on the Morph side
    A System: Work: Data: Data1:(FAT files).
    Can I avoid reintalling the Mac OS?
    The Dual Boot had three partitions as the defacto set up.
    TIA ;-)
    three partitions now work system data on the morph side
    [ Edited by osco on 2009/12/18 21:36 ]
  • »18.12.09 - 17:44
    Posts: 2581 from 2003/2/24
    Sure, delete the existing MorphOS(SFS) partition, and than use the freed space to create as many partitions as you like.
  • »18.12.09 - 18:03
    osco
    @Kronus
    How do delete that partition? and sub divide it?
    HD tool box?
     8-)
    [ Edited by osco on 2009/12/18 15:18 ]
  • »18.12.09 - 18:16
    pampers
    Posts: 1071 from 2009/2/26
    Don't forget that when you delete existing MorphOS partition, you will loose all current settings, libraries, mui classes etc. so some applications might not be working straight away after reinstalling MorphOS.
    MorphOS 3.x
  • »18.12.09 - 18:21
    osco
    The partitions on the MOrph side (Boot and System) are now corrupt. The Mac Partition is ok. Going back to Morph Install CD and try the manual install again with an eye to delete the system and boot partitions and subdivide into four partitions: System: Boot: Data: Data:(fat file system) to add to the MacX already on the drive.
  • »18.12.09 - 18:26
    osco
    The installation is in its beta stage so its a bit morphic sorry for the pun.
    I realize it will be work in progress for a bit :-o  :-o  :-o
    The advice from the team fell on deaf ears on changing files and third party ornaments :-)
    [ Edited by osco on 2009/12/18 15:32 ]
  • »18.12.09 - 18:30
    Posts: 2220 from 2003/2/24
    Just follow the dualboot guide from the MorphOS installation part and resize the big partition (1st big, dh1 IIRC) for the MorphOS smaller and create new similar partitions to the empty space. Shouldn't be difficult. If you don't want to make new partitions in install stage yet, just leave empty space there and add extra partitions later with HDConfig on MorphOS.
  • »18.12.09 - 18:51
    osco
    Ty all!
    Reinstall successfull.
    Trial and error sometimes the best teacher 8-)
    There is no menu per se so after many attempts The old partition was deleted(right click on it and it ask edit or delete?
    follow the trail and intuition 8-)  8-)  8-)  8-)  8-)  8-)
  • »19.12.09 - 00:34
