I've taken the plunge :)
    ddewbofh
    Posts: 25 from 2009/12/4
    So after a few weeks of investigation I finally got hold of a Mac Mini with decent specs and bought MorphOS. It's been close to 15 years since I last used an Amiga-like system properly so it's a fun learning experience. But on to some questions:
    1. Where's the speed? Everyone says how fast the system is and how well the GUI works but so far I'm not seeing it. The compositing is slow, so is opening apps or any kind of harddrive access. It boots up really fast though. :)
    2. Are there any "Amiga/MorphOS for dummies"-guides available? Been using WinNT and Unix so long that I'm struggling to remember the basics. Preferably documentation explaining basic terminology, filesystem-layout, quirks and things like that.
    Thanks
  • »15.12.09 - 12:31
    xyphoid
    Posts: 870 from 2008/7/11
    Speed is relevant to what you're comparing it to, surprising you don't see it though. Can't say you installed it right, someone else will determine that. If you used sfs formatting, it should be evident. Harddive access is the fastest I've seem especially on usb.
    Can't answer for the guide. This site has some threads in regards to guides.
    Welcome over, and keep asking question, and have fun!!
  • »15.12.09 - 12:51
    Posts: 423 from 2005/4/9
    hi and welcome!
    1. i guess your mini has 32 mb videomem. try disabling 3d screens (system prefs/screens/uncheck enhanced layers). what resolution do you use? it shouldnt be slow, morphos on mini is blazing fast or it should be.
    2. look at the library section here at morphzone. also try to get the pegasos book (outdated but still has valuable informations about morphos)
    zx.spectrum@3.5
  • »15.12.09 - 12:53
    ddewbofh
    Yeah, I'm using SFS so that shouldn't be the cause. But having read up on the specs of the mini I see that the harddrive it ships with runs at 4200 rpm which has to be a huge bottleneck. :)
  • »15.12.09 - 13:00
    osco
    Posts: 680 from 2009/10/20
    Welcome
    I am a few weeks ahead of you. It's great not being a user. I have dual boot but I use the Mac OS less and less. Owb (browser) is fast and a joy. It has updates version1.6 with Flash. the threshold is daunting but an Amigian will be very happy here 8-)  8-)  8-)  8-)
    There are guides to upgrading the Mini hard drive
    [ Edited by osco on 2009/12/15 10:05 ]
  • »15.12.09 - 13:03
    ddewbofh
    Yeah, the threshold is what brought me here. After "mastering" winnt, unix, linux and beos/haiku I needed a new fix. I've been looking at getting an amiga or something to run morphos on but the efikas etc were way too pricey and slow for my taste. Adding support for Apple's G4's was a brilliant move making it easy to get hold of decent hardware for a decent price.
    One thing that really sticks out is how much this feels like AmigaOS for the 21st century, Like an old car with a new paintjob, engine and drivetrain. :)
  • »15.12.09 - 13:15
    Daff
    Posts: 251 from 2003/4/5
    To speed up your Mac mini, you can change the hard drive (7200 rpm), put 1GB of memory, disable totally 3D compositing, and add a command in the open firmware to speed up the boot time :
    setenv skip-netboot? true
    There is an article (french) about speeding up a Mac mini :
    http://obligement.free.fr/articles/ameliorer_macmini.php
  • »15.12.09 - 13:28
    jcmarcos
    Posts: 1178 from 2003/3/13
    Guess what? I don't think so: You've seen already just how fast MorphOS boots... And that's perhaps the most stressing moment for the hard drive. As MorphOS doesn't rely on virtual memory, in normal use disk activity is exactly where it should be at: None.
  • »15.12.09 - 13:43
    ddewbofh
    I'll look into the compositing idea, running at 1920x1200 could be a little much to ask of this chip even if it's got 64MB vram and handles compositing just fine in OS X. That could account for the occasional slowdowns when opening apps and windows.
    Thanks
    Edit: Switched to 1920x1200x16bit and now everything feels "teh snappy", much better. :)
    [ Edited by ddewbofh on 2009/12/15 17:04 ]
  • »15.12.09 - 13:58
    ddewbofh
    Ok, I'll have to eat my words on this one. After sorting out the screen issue the system feels insanely quick. Even feels faster than my Core i7 machine on some tasks like browsing the filesystem or searching for stuff. A very pleasant surprise considering this whole setup set me back less than 400?. :)
  • »15.12.09 - 14:26
    Debaser
    Posts: 161 from 2005/7/12
    Welcome to Morph OS and Morphzone!
    The library section is great so be sure to check that out as well as the download section of this site as well as Aminet.
  • »15.12.09 - 14:37
    metalmac
    Posts: 87 from 2007/5/26
    Welcome onbord! MorphOS is great!
    PowerBook G4@1.5Ghz, 1Gb ram, MorphOS 3.12
    Amiga 1200, Blizzard 1220/4@28Mhz, 500Mb HD, 6mb RAM, Workbench 3.1
    AspireOne, 1Gb RAM, 160Gb HD, Icaros Desktop
    AmigaOne 500, 2Gb ram, AmigaOS 4.1 Final Edition
  • »15.12.09 - 15:27
    manga
    Posts: 41 from 2009/5/6
    welcome to da freakzzz :)
    if you got problems with 24bit/1900x1200 and have 64mb vram mac mini, check the graphic utility from your morphos installation. are there also 64mb of ram, not only 32mb recognized? there's a bug in morphos2.4 with the detection of radeon9200 memory size, wich also slows down 64mb minis in high screenresolutions. normally 64mb are enough for the 3d layers mode with your screen resolution. read the forum for temporarly fixes...
    enjoy your trip :)
    Powermac MDD 1,25GHz Radeon 9000 Pro 128MB, 1,5gb, Terratec Aureon Space, USB2.0 NEC, MorphOS 2.6 regged, Powermac MDD Dual1.42, Radeon X800XT PE 256MB waiting for r300 support, Mac Mini 1.5GHz MorphOS 2.6 Regged, Efika Radeon 9250 128MB Morphos 2.6
  • »15.12.09 - 15:50
    Velcro_SP
    Posts: 929 from 2003/7/13
    [ Edited by Velcro_SP 26.06.2011 - 17:06 ]
    Pegasos2 G3, 512 megs RAM
  • »16.12.09 - 11:26
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    @Velcro_SP
    No, your issue is entirely different. And you know it, since it also happens when it's disabled (remember these dragged icons? :)).
  • »16.12.09 - 12:05
    Velcro_SP
    [ Edited by Velcro_SP 26.06.2011 - 17:03 ]
  • »16.12.09 - 16:04
    DiskDoctor
    Posts: 306 from 2009/4/17
    @ddewbofh
    Hi and welcome here.
    Ad. 1. I disagree. I mean having my configuration (which is said to be a nice one), I can say it's much faster than my Windows7 (1.8GHz Intel, 1 GB RAM, 256MB SoC gfx shared with RAM), slightly faster than Kubuntu9 (on same spec PC), and "runs circles" :-) around my MacOS Tiger (same Mini :-))
    If you still complain, please read all (biased? so what?) MorphOS vs. AmigaOS comparisons. I guess you might be more dissapointed while getting OS4 instead of MOS, probably. Hell, I'll get AmigaOS anyway, when I got cash.
    Also, Please use such dock solution as PolyNet NG, to be downloaded from this very site. Any system without the launcher is much much slower. This software has some issue with saving prefs regarding onscreen bar location, I managed to save it properly just yesterday.
    Why blaming the speed whilst you can enjoy the new refurbished :-) Amiga Land?? Take your time while here.
    Was: Mac Mini PPC running MorphOS 2.4
    Now: Amiga Forever 2010 with AmiKit and AmigaSYS
    Not used: Icaros Desktop 1.2 (reason: no wifi)
    Planned soon: an OS4 system
    Shortly then: a MOS notebook (wifi is a must-have)
  • »16.12.09 - 17:31
    ddewbofh
    Hehe, I'm not saying my system is slow or anything just that after reading about it and seeing some videos it looked a lot faster. But I've managed to get the OS working like it should now and so far my only "complaint" is my slow networking.
    As for the choice between this and AmigaOS the decision was easy. It's almost impossible to get hold of an Amiga nowadays and I'm not very impressed with the later incarnations of the OS, I get the impression that it's pretty outdated.
    Thanks for the tip about PolyNet, atm I'm using the built-in panels for launching apps and it's pretty basic.
    But so far I'm loving the experience, despite any bumps. It's something completely different much like the BeOS so I'm bound to enjoy the ride. Now I just need to wrap my head around the "screens" concept and figure out how to change wallpaper and I'm all set. :)
  • »16.12.09 - 18:21
    Posts: 2732 from 2003/2/24
    MorphOS is Amiga *done right*! :-P :-)
  • »16.12.09 - 18:35
    ddewbofh
    Yeah, that's kind of what I was aiming for, didn't want to step on any toes. :-)
  • »16.12.09 - 18:38
    Posts: 2095 from 2003/6/4
    ddewbofh wrote:
    ...figure out how to change wallpaper and I'm all set. :)
    right mose button -> settings -> ambient -> backdrops
    Very stright forward.
    Screens:
    rmb ->settings-> system -> screens
    There you can setup your screens. Chose a name for a screen, select its resolution and desired skin, decide whether it should use enhanced gfx mode or not..
    Once you set up a screen you can use it for your appa. Either determine in the prefs of the program to get launched on a particular screen or just dump a running program to a particular screen by its MUI menu (LMB on the MUI gadget in the right window corner, select "jump to screen"), selcet the screen you want from th econtext menu.
  • »17.12.09 - 07:34
    ddewbofh
    Wow, now I feel really thick. I must've looked through every prefs app imaginable and still missed it. :)
    The jump to screen thing can be very useful, thanks.
  • »17.12.09 - 11:49
