RAM:env
  • TGR
    TGR
    Posts: 100 from 2009/10/26
    This is probably my fault and a user mistake.
    I've installed UAEload and it works fine accept from a problem I'm having. In the install instructions it says to put the uaeload.conf file in ENV. so I've put it in RAM:env! but I made a mistake in the file, so I corrected the mistake and put the new conf file into ram:ENV and on every reboot the file goes back to the first conf file (that I made the mistake in) so everytime I want to use UAEload I need to replace the config file.
    Can anyone give me some help on this matter.
    Mini Mac G4 1.25, 1gb ram, 40 gig hdd, Registered Morphos 2.6.
  • »07.12.09 - 01:49
    Posts: 1099 from 2004/9/23
    I am not an expert in UAE, but it sounds like you need to replaced the file in ENVARC:. The drive ENV: (ram:env) gets cleared on each reboot and restored from ENVARC: (sys:prefs/env-archive).
    Thats why changing in ENV: has no effect.
    Geit
  • »07.12.09 - 04:50
  • TGR
    TGR
    Thank you Geit problem sorted  8-)
  • »07.12.09 - 09:38
