how to change partitions on macmini after dual boot installa
    Drayman
    Posts: 18 from 2004/5/17
    I made 3 partitions like discribed in the dual boot instructions manual.
    Now I would like to replace the MorphOS SFS partition by 3 different SFS
    partitions. Is this possible or do I have to reinstall dual boot?
    Thanks for answers, Drayman
  • »18.11.09 - 05:12
    Posts: 3336 from 2003/3/5
    Remove the SFS partition and add the new ones in its place.
  • »18.11.09 - 07:38
    osco
    Posts: 680 from 2009/10/20
    Remove the SFS partition and add the new ones in its place"
    In a cave: How do you remove the partition?
    Use the tool in MorphOS 2.4?
    What is in SFS partition? It is DH1: and was named "System" in the installation process.
    If you remove this partition wouldn't affect MorsphOS 2.4 :-?
    TIA
  • »18.11.09 - 11:31
    Obviously you do that on MorphOS with the HDConfig tool. You will have to reinstall MorphOS afterwards. It is not possible to resize SFS partitions.
  • »18.11.09 - 11:40
    osco
    Ty  :-)
    Seventh Installation My hard drive is swearing at me 8-)
  • »18.11.09 - 12:21
    Posts: 12558 from 2003/5/22
    AFAIK, shrinking is possible.
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=5146&forum=9#49628
    http://www.amiga-news.de/en/news/AN-2005-06-00081-EN.html
  • »18.11.09 - 15:55
    Drayman
    All went ok. Resize worked and MacOSX starts up too.
    What about the blocksize? Any chance to get other than 512?
    Is it limited by the MAC partition table?
    Thanks, Drayman
  • »18.11.09 - 21:37
