If you are attempting to install MorphOS on a Mac mini, plea
    osco
    Posts: 680 from 2009/10/20
    An Old "newbee"..I have the retail version of Leopard....How do I resize an existing installation that resides om one partition? Or directions to the manual
    TIA
  • »16.11.09 - 00:48
    osco
    If you are attempting to install MorphOS on a Mac mini, please note that IWizard will format the drive automatically, destroying the previous contents of the hard drive. Instructions on how to install and configure MorphOS to run alongside other operating systems will be provided at a later date.
    Rest of subject header
  • »16.11.09 - 00:50
    Posts: 3311 from 2003/3/5
    http://dreamolers.binaryriot.org/dualboot.pdf
  • »16.11.09 - 02:50
    Posts: 12539 from 2003/5/22
    He already knows your excellent guide multiple times ;-)
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6568&forum=3
  • »16.11.09 - 06:01
    Ruud
    Posts: 335 from 2009/2/2
    I hope osco understands the guide better than I understand him ;-)
    (I know that's a damn cheek coming from a native english speaker who can't communicate in any other language, but hey I'm a cheeky guy ;-) )
    edit: Sorry I'm being unfair. He's making much more sense in this thread than in previous ones.  :-)
    [ Edited by Ruud on 2009/11/16 10:45 ]
  • »16.11.09 - 09:37
    osco
    ROFL In a cave and being battered by fellow trolls: Gotta love the Amiga :-)
  • »16.11.09 - 10:48
    osco
    RTFM! but where/ going to the search engines and APPLECARE :) :-o
  • »16.11.09 - 12:58
    If your question is "how do I resize existing partitions to create another partition so I can then install MacOSX Leopard and have a dual boot system from what you now have as only a single boot MorphOS2.4 system" then just boot from the Leopard DVD and start the Disk Utilities program.
    If not, then please explain again what you are trying to do.
  • »16.11.09 - 21:53
    osco
    Bit the bullet and started from scratch and failed........
    Did a clean install of OsX.
    Got three partitions with OSX on the third partition
    Got the boot partition on DH0
    But failed on DH1..
    Now how to start fresh install of MorphOs? :-?
  • »17.11.09 - 00:50
    kickstart
    Posts: 227 from 2009/4/28
    I cant help you with this dual boot, my mini just have morphos but...
    Whats your native language?
    Maybe someone here can help in your native language, with all respects some times its hard to understand your post (more than mines heh).
    [ Edited by kickstart on 2009/11/17 3:28 ]
  • »17.11.09 - 02:27
    But failed on DH1..
    Are you using the fine dual boot pdf that has been provided? In what way did your installation fail? At what point in the instructions given in that dual boot pdf did your installation fail for MorphOS2.4?
    I used it and had no trouble, except for the part where I backed up my MacOSX hard drive and then tried to re-install it and found that the second time I went to do the re-install, the files were all gone from the DVD-RW that I put them on.
  • »17.11.09 - 02:52
