Frame grabber USB is there any way through MORPHOS 2.4?
    osco
    Posts: 680 from 2009/10/20
    Wish to grab a Flash video through the Mac Mini. How to? :-)
  • »15.11.09 - 16:58
    Posts: 2539 from 2003/2/24
    You could start by actually explaining what it is you want ...
    Flash ? USB ? Frame grabber ? WTF !!!!
  • »15.11.09 - 17:17
    Tcheko
    Posts: 540 from 2003/2/25
    You can try getvideo (http://www.morphos-files.net/find.php?find=getvideo)
  • »15.11.09 - 17:19
    koan
    Posts: 303 from 2005/11/21
    A frame grabber is hardware to capture a digital image from analogue video.
    I think you mean you want to convert a Flash video to another format ? If it's Flash video (FLV) and not a Flash animation then you can do that with mencoder. FLV is actually MPEG-4, IIRC.
  • »15.11.09 - 17:54
    osco
    http://www.epiphan.com/
    Wish to use this hardware to bring a "Flash" video into the MorphOS to be further processed by legacy Amiga 3.1 applications with AREXX ports 8-)
  • »15.11.09 - 18:12
    Posts: 12498 from 2003/5/22
    That's one possibility. FLV can also be VP6, Sorenson Spark or Screen video. Refer to:
    http://en.wikipedia.org/wiki/Flash_Video#Codec_support
  • »15.11.09 - 18:31
    koan
    That is very expensive hardware. I think you can find other, cheaper, ways to make a screencast.
    Why do you need to grab in FLV ? Do you already have the hardware ?
    The majority of FLV is MPEG-4. Considering these devices have MPEG-4 as an output option the chances are that's the version of FLV they are using.
  • »15.11.09 - 18:41
    MPEG-4 has become a possible FLV encoding only 2 years ago. I wouldn't dare to make any such definite statement about proportion as of now ;-)
  • »15.11.09 - 19:01
