Posts: 820 from 2008/3/30
Hi all!
I know a similar topic exists. But that was solved. Here the problem is present.
I've read "how to" and I performed Geit system. Boot on without battery, I appeared registered.
So I inserted the battery, adjusted date and time reboot and all ok. Turned on and all ok.
Now I turned on and I'm not registered.... An the battery is a new one...
Is there any different problem when this happens?
I woudn't think something is going to broke.... A couple of hard disk freezes (it seemed a psu problem, but I'm not sure...) could be dangerous signs?!?
[ Edited by Jambalah on 2009/11/14 17:19 ]
Pegasos II 1 ghz
Powermac G5 dual 2.0 ghz
Powerbook G4 1.67 ghz 17
