Bootloader (as bootcreator) for Mac Mini G4
    Divinity
    Posts: 532 from 2009/9/8
    Is there a bootloader (as bootcreator for Pegasos2) for Mac Mini to bootstrap O.S. MorphOS 2.4, Linux Debian "Lenny" 5.02, and eventually also OSX Leopard 10.5.8 ?
    If yes, Is there a tuorial/guide/manual to use it correctly ?
    thanks a lot
  • »08.11.09 - 12:22
    tokai
    Posts: 1289 from 2003/2/25
    The Mac mini has a "bootloader" build-in; just press ALT during early boot stage and some graphical menu will show up which allows you to select the boot partition/ operating system.
  • »08.11.09 - 14:48
    Chain-Q
    Posts: 350 from 2003/10/12
    Linux has a bootloader (Yaboot) built in. It usually detects and makes already installed systems bootable via it's menu. If you don't use Linux, you don't need to have a bootloader, as both MorphOS and OSX can boot from the built-in OF menu, as tokai mentioned. So there's no need for a tool similar to bootcreator.
    [.Hosting AmigaSpirit.hu.]
  • »08.11.09 - 14:56
    Divinity
    hi,
    I need a bootloader Linux; ok Yaboot, but is there a guide/tutorial/manual to adapt It with MorphOS, Linux, OSX Leopard...
    thanks
  • »08.11.09 - 16:01
    Posts: 12570 from 2003/5/22
    BootCreator is nothing like that. It's just a program to output a Forth script to be executed by the Pegasos OpenFirmware. The (non-graphical) "bootloader" is integrated into that OpenFirmware.
  • »08.11.09 - 21:07
    Chain-Q
    @Divinity
    Simply install Linux as the last system on the mini, and it should add existing systems to its bootmenu. (Theoretically, i haven't tried this.)
  • »09.11.09 - 08:21
