Radeon 9250 256Mb AGP problem with MorphOS 2.x (Pegasos2)
    Divinity
    Posts: 532 from 2009/9/8
    Hi Fab,
    updated the firmware to 1.2 version (recived today by Bplan), now It's enabled the 10/100/1000 eth in MOS and Linux :)
    My Peg2 is relase 2B2 so the right Smart Firmware update is 1.2 (20040810).
    Le update is easy, if you have 2B2 version This the right firmware update.
    With this update you can also use usb keyboard Apple in Smart Firmware.
    not answare at the moment from pega-1
    thanks
  • »02.11.09 - 14:20
