How do you move a downloaded/extracted program from the Ram:
    osco
    Posts: 680 from 2009/10/20
    From an old Dopus user
    laters 8-)
  • »01.11.09 - 23:28
    osco
    How do you move a downloaded/extracted program from the Ram:to a new system folder..I downloaded OWB 1.5 and I wish to upgrade MorphOS2.4 with it. :-P
  • »01.11.09 - 23:30
    Have you tried dragging and dropping it where you want it copied? There is also the right mouse drop menu where you can highlight a file and cut/copy/paste it just like in almost any other computer system. Those are the two most used ways I move files, but there are a few more as well that others might suggest.
  • »01.11.09 - 23:32
