First steps in MorhOS 4.2
    osco
    Posts: 680 from 2009/10/20
    Thank-you all for the posts for Osco in the cave! Yesterday I had the MORMAC up and was browsing with OWB. It hit some hitches (yahoo mail) but no matter. Ready to start and with the manuals
    should get up to speed. I was one of the past Amiga users who took advantage of MorphOS 2.4, got a $256.00 Mac Mini off of ebay; got the right keyboard and mouse, and installed the system with the forum's help.
    Laters,
    Osco :-)
  • »01.11.09 - 14:45
    Jambalah
    Posts: 820 from 2008/3/30
    Glad you are enjoying this new and really good release of MorphOS!
    ...I envy you a little... I haven't downloaded the 4.2 version yet...  ;-)
    Obviously, I'm kidding.... I really hope MorphOS could overcome that line!
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »01.11.09 - 15:03
    osco
    LOL I prefaced with First steps..... MorphOS2.4 8-)
  • »01.11.09 - 15:24
    kriz
    Posts: 314 from 2005/10/18
    welcome ! I also use the mac mini with Mos as my main system at home now.. its great ;)
  • »01.11.09 - 15:27
    Ruud
    Posts: 335 from 2009/2/2
    @osco
    If you want to use Yahoo mail with OWB you need to enable the experimental cookies. To do that open the OWB settings from the drop down menu under "Preferences" and select the"Network" section and enable the "Experimental cookie system". Save and restart OWB and you should be able to access Yahoo mail. At least that works for my Girlfriend's account ;-)
    [ Edited by Ruud on 2009/11/1 17:25 ]
  • »01.11.09 - 16:23
    Trezzer
    Posts: 19 from 2003/12/21
    Oh great. Thanks.
    It was driving me bonkers that I had to use m.yahoo.com to access Yahoo! Mail. At least this way I can access the old version. It also seems to make Gmail work a bit better. Now the full version almost works completely (with the normal cookie system I could only get the basic version working right).
    Mac Mini 1,25GHz G4 512 MB RAM 40 GB HD - running MorphOS 3.0
    Powerbook A1138 1 GB RAM 80 GB HD running MorphOS 3.2
  • »01.11.09 - 17:31
    Ruud
    No problem ;-)
    One thing though - If you want to use paypal, you'll have to switch it back off again :-(
  • »01.11.09 - 17:41
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Both cookie systems currently suck yes, differently. But at least i give choice there. :)
    The new one (completely done by OWB authors) will be the one used in the end, but it certainly needs more work. The old system relies on CURL cookie handling.
  • »01.11.09 - 18:49
    Debaser
    Posts: 161 from 2005/7/12
    Ruud wrote:
    @osco
    Rudd - thanks a million! That helped me out quite a bit with gmail. And thanks again Fab for your OWB work as well. :)
  • »01.11.09 - 19:13
    osco
    @ Fab,
    Is there a spoof to Ie in OWB?
  • »01.11.09 - 19:57
  • Fab
    Fab
    If you have downloaded OWB 1.5, go to settings->network section and choose the browser to spoof as.
    If you're still using OWB 1.4 (or older), you need to type in a shell:
    setenv OWB_USER_AGENT "the browser user agent string"
    and then you run OWB.
    But i advise you just use OWB 1.5, it's easier.
  • »01.11.09 - 20:09
    osco
    @ Fab
    Have downloaded OWB 1.5 and was embarrassed how to extract the lha.
    I didnt realize I had version OWB 1.4 which is included in MorphOS 2.4
    ty again
    osco :-)
  • »01.11.09 - 20:40
