Posts: 680 from 2009/10/20
RTFM:
Troubleshooting for Mac mini G4 users
Q: My Mac mini doesn't boot, all I get is a gray Stop sign. What to do?
A: This may mean that the selected boot.img file or the filesystem Mac mini boots from is corrupt. Boot MorphOS from the CD, mount the HFS Boot partition with Mounter, format it using Ambient's Format menu (remember to name it Boot) and copy files found in mac_ppc32 directory on the CD to the freshly formatted Boot: partition. Now open a shell and type 'HFSSetMacBoot Boot:bootinfo.txt'. Finally, eject the CD and reboot.
Q: My Mac mini doesn't boot, all I get is a blinking disc icon. What do I need to do?
A: It may be that the HDD wasn't detected or that its partition table is damaged. In case you have your data backed up, the best way would be to try reinstalling MorphOS. You may also want to run HDConfig from Tools to see if the HDD is detected and has the proper partition layout.
Q: My Mac mini doesnt't boot, all I get is a black screen / my monitor doesn't power on. What are my options?
A: Try to erase the nvram. This is done by holding Command + Option + P + R keys after hearing the chime sound after you power on the mini. You should keep the keys pressed until you hear the Mac reboot itself again. Even if the chime sound was previously muted, you should hear one now.
Q: I tried erasing nvram, but it doesn't help. What else can I do?
A: You may try the same key combination, but this time power the mini off, hold the Command + Option + P + R keys and press and hold the power button with your third hand. Keep all keys and the power button pressed until you hear the Mac mini reboot again.
If this does not help, you should probably send the machine to your local service center.
Q: My Apple USB keyboard does not appear to work. Why is that?
A: We have successfully tested Apple's A1048 and M7803 keyboards but discovered compatibility issues with the A1242 and A1243 models, which at present have to be considered incompatible with MorphOS.
