What type of bridge (if any) between MorphOS 2.4 and Mac OSX
    osco
    Posts: 680 from 2009/10/20
    How would exchange data between the OS's. Amiga Forever comes to mind. Where the hard drive with Windoz files are shown on the Amiga side in Dopus
    TIA
    Osco
  • »30.10.09 - 20:11
    Posts: 2095 from 2003/6/4
    You can access your OS X partitition by Ambient after you mouted taht partition.
    Go to sys:tools/mounter.
    Select ide.device unit 0
    and chose your mac paritition from the list and click on "mount".
    Voila -your mac had appears in Ambient.
    Edit: Currently you can only access inread only mode to hfs+. So if you want to share things in both directions your best off with a hfs partition. That one should be r/w from MorphOS and OS X then.
    [ Edited by Zylesea on 2009/10/31 0:23 ]
  • »30.10.09 - 20:19
    Easiest way for me is to just use a USB memory stick.
  • »30.10.09 - 23:15
