How to burn the iso image of MorphOS 2.4
    osco
    Posts: 680 from 2009/10/20
    Newbee to Mac.
    Go to download site and download MorphOS via Safari.
    As the download is completed a requestor asks if I wish to open the Iso with the warning that it may affect the OS of my wife's Apple. I refuse to open it. what now?
    I want to burn it on a cd
    How do I do it?
    Put blank CD in the "burner"
    Should I name it?
    Osco trembling.
    Seems like I,m on an old adventure came...N<W<S<E<up down
    TIA 8-)
  • »30.10.09 - 00:57
    osco
    Hint: burn the ISO as the CD?s image, not as a file on the CD ; What does this mean? A CD's image? The CD inserted was a blank CD with no other files?
    In a cave
  • »30.10.09 - 01:29
    Posts: 3311 from 2003/3/5
    To burn an ISO file on OS X you need to use either Disk Utility or Toast Titanium. With Disk Utility, insert a blank CD, select the CD burner in the drives list, find the Restore function in Disk Utility. Drop the .iso file into Source and the CD-R/DVD-R into Destination. Restore the iso and you should be able to boot from it. With Toast this should be even more trivial.
  • »30.10.09 - 04:45
    Posts: 33 from 2003/6/17
    SimplyBurns is a simple and tiny burning app for OS X. It burns ISOs (Wii-ISOs as well) and is free.
    Robert
    PegII, 512 MB Ram, Radeon 8500, NEC USB-Card
  • »30.10.09 - 08:11
    DiskDoctor
    Posts: 306 from 2009/4/17
    grooves wrote:
    Robert
    DiskUtility is also free, it's part of the system.
    @jacadcaps
    Not sure but I guess one has to mount the iso also, prior to dragging it for burning on a CD. ?
    Was: Mac Mini PPC running MorphOS 2.4
    Now: Amiga Forever 2010 with AmiKit and AmigaSYS
    Not used: Icaros Desktop 1.2 (reason: no wifi)
    Planned soon: an OS4 system
    Shortly then: a MOS notebook (wifi is a must-have)
  • »30.10.09 - 12:55
    osco
    In a cave
    At the end of the download operation a prompt request if I wish to "mount the download"?
    Why? It says it may affect the wifes Mac? 8-)
  • »30.10.09 - 14:15
    osco
    Install disk burned and working :-)  :-)  :-) My concern was with opening on a mac that was not the destination computer which my wife's computer wanted to do. It was pref to open download files :-x
  • »30.10.09 - 20:03
