Graphic glitch when changing res. on mini
    _ThEcRoW
    Posts: 298 from 2008/10/27
    Hello friends, someone has changed resolution from 24 bit to 16 and get suddenly the screen very bright?. It was like brightness was put to max. Of course i rebooted and it was no more, but don't know it there is known problems using the 32mb vram model. Other than that, mos flies on the mini and i'm very impressed by the work done.
    Thanks!!!
  • »21.10.09 - 08:22
    Crumb
    Posts: 736 from 2003/2/24
    It's a known bug and it happens in all mac mini models and Efika too (it's related to DVI IIRC).
  • »21.10.09 - 11:54
    kickstart
    Posts: 227 from 2009/4/28
    Bug or not. original DVI 2 VGA apple conversor have some bugs with crt monitors, they start to dark.
  • »22.10.09 - 04:03
    _ThEcRoW
    Ok, now i can sleep fine knowing that is not a problem of my installation or machine. Any idea if it will be solved in the future?.
    Thanks!!!
  • »23.10.09 - 23:30
    BalrogSoft
    Posts: 171 from 2006/10/6
    I can confirm this bug on my Efika, even using VGA output of Radeon 9200P.
    Balrog Software - AmigaSkool.net
    Mac Mini - MorphOS 3.8 - G4 1.5Ghz - Ati 9200 64 Mb
    Efika - MorphOS 3.6 - Ati 9200 64Mb - 80 Gb HD
    Amiga 1200D - OS 3.9 - Blizzard 603e/240mh
  • »24.10.09 - 13:46
    Posts: 594 from 2003/4/11
    In fact this should only happen with analog VGA output and is unrelated to digital DVI. If you select a 75Hz 1024x768 mode, it interferes with the TV output on Radeon 92xx cards (which is used inside the mini as well). The screen gets too bright and it is not reset to normal levels if you change the screen resolution again. Only certain resolutions are affected.
  • »24.10.09 - 15:30
