mos 2.4 slow internet on macmini
Topic is Locked
    kickstart
    Posts: 227 from 2009/4/28
    Well, subject says all... on my macmini the maximun speed is 10kbs some times, i just read some users with this problem but no more, anyone know a solution?
  • »19.10.09 - 01:25
    kriz
    Posts: 314 from 2005/10/18
    I have tried and downloaded some big files, seemed fine.. When do you notice this ?
  • »19.10.09 - 14:21
    kickstart
    From the first time connected, downloading small files like cpugauge, memorygauge, using owb and sputnik. Its frustrating to use on the internet  :-(
  • »19.10.09 - 14:37
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Likely wrongly set network or bad cable.
    I had that issue with my (sucky) router. I plugged differently and it works much better now.
  • »19.10.09 - 15:46
    pampers
    Posts: 1068 from 2009/2/26
    My internet connection is about half slower on MorphOS than on other systems at my home. On Win7 i'm getting about 800kb/s when downloading from the internet. On OSX on my Mini i'm getting about the same speed. But on MorhphOS the max i get is 300-400kb/s.
    MorphOS 3.x
  • »19.10.09 - 16:02
    TiredOfLife
    Posts: 86 from 2009/10/13
    Internet seems a bit slow for me also with the MorphOS/Mac Mini combo.
    Will do some proper tests in the next day or so.
  • »19.10.09 - 16:21
  • Fab
    Fab
    Here i get about 8MB/s locally (be it on peg or mac mini).
    Anyway, one thing that could change speed a bit is the TCP window setting, which works just like it did in AMITCP...
    So, envarc:sys/net/netstack.config
    TCP_RECVSPACE=32768
    TCP_SENDSPACE=32768
    (Don't go for higher values, because it can have unwanted consequences :)).
  • »19.10.09 - 17:30
    Divinity
    Posts: 517 from 2009/9/8
    I also have this problem
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6517&forum=3
  • »19.10.09 - 18:57
    Divinity
    @Fab
    tried, but always the same problem.
    If I reboot in OSX Leopard, I don't have this problem.
    [ Edited by Divinity on 2009/10/19 22:10 ]
  • »19.10.09 - 19:10
    kickstart
    Its the same for me, same ethernet cable with shame router runs fine on another OS but in MOS is slooooow, at least im not the one with this bug, hope for a solution, loocking on google all link come to this forum no fix at the moment.
  • »19.10.09 - 20:11
    Divinity
    here now:
  • »20.10.09 - 15:43
    kickstart
    yes, moderators can close this thread.
  • »20.10.09 - 18:53
Topic is Locked
