Posts: 820 from 2008/3/30
Tested a little more:
Mime Type: text /* doc
Extension: doc
Action: external viewer (or ask, as you like)
Viewer: (your directory):antiword -f -i #80 ( next box): %f
As the explanations doc is not so clear, (I mean, no pratical example for a newbie like me)
I tested and with this command/mime I'm able to read .doc texts.
I don't know if images will be diaplayed (though the "-? #0" is a switch for images)
but reading a text works.
The strange thing is that everytime antiword open a text, it shows in the top the "I can find the name of your HOME directory" prompt.
I don't know where is this directory, nor I solved the "problem" creating one and naming it "HOME".
I'm going to read the docs again...
Pegasos II 1 ghz
Powermac G5 dual 2.0 ghz
Powerbook G4 1.67 ghz 17
