one more app for morph
    xyphoid
    Posts: 870 from 2008/7/11
    Make your own deductions:
    http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=29038&forum=32#496801
    Posted with OWB1.3
  • »14.06.09 - 16:54
    Posts: 1075 from 2003/3/24
    Check our Bounties out we got something better in the works:
    http://www.pegasosforum.de/viewtopic.php?p=40015#40015
    Read Kronos status reports below on the linked page
    oh and here you can donate:
    http://bounties.morph.zone/bounties/show/8
    We have till now collected about 131 Euro, the donations need an update.
  • »14.06.09 - 18:22
    xyphoid
    Are both donations going to the same source?
    I'm donating to http://bounties.morph.zone/bounties/show/8
    Nice to know, had no idea. Has it been assigned to Kronos then?
    He should place an update here too from time to time
    posted from vista :-x atleast posted with chrome ;-)
  • »14.06.09 - 19:59
  • Bounty Manager
    insane
    Posts: 68 from 2003/5/20
    Hi !
    At the moment, there are 2 different bounties.
    1. X11 Wrapper (initiated at morph.zone)
    This bounty is actually NOT assigned
    2. GTK-MUI Wrapper (initiated at pegasosforum.de)
    http://bounties.morph.zone/bounties/show/15
    This bounty is assigned to Kronos
    I will see if we can link this two bounties togehter.
    For the moment i would recommend to donate for the GTK-MUI bounty,
    because it's assigned (and the X11 is not)...
    Insane
  • »15.06.09 - 19:32
    xyphoid
    Thanks insane! that's the clarification I was looking for.
  • »15.06.09 - 21:00
    Crumb
    Posts: 736 from 2003/2/24
    @ThePlayer
    Although gtk-mui wrapper sounds very nice I always wonder what happens with custom gtk gadgets. IIRC gtk 2.6.x and later versions can draw them using Cairo but I'm unsure about GDK being required... or does GDK depend on Cairo?
    I think that the main problem are the custom gadgets, applications like pidgin use different custom gadgets and some GDK functionality may be required to get them working
  • »16.06.09 - 20:18
    Posts: 1520 from 2003/2/24
    GDK is needed but it is possible build GDK wrapper once GTK-MUI is finished. It is just lot of work.
  • »17.06.09 - 05:13
