kinda random. can anyone answer?
    poundsmack
    Posts: 1346 from 2003/6/7
    hmmm u can't see any of my text. well i was wondering if anyone knew where i can find the backround that it is in this screen shot I MUST HAVE IT hehe. so if anyone knows please post the link.much apreciated thanks guys.
    -chris
    [edit] ok now u can see the text]
    "Poundsmack, official morphzone thread creator" -LorD
    "Wanna be lord of the avatars." -JKD
  • »14.10.03 - 03:55
  • Targhan
    Posts: 2833 from 2003/2/7
    what image? The link appears to be broken.
    :idea:Targhan
  • »14.10.03 - 04:17
    poundsmack
    i can see the image on my web browswer (internet explorer) it it is a bmp. image should i do it a jpg?
  • »14.10.03 - 04:51
    Posts: 35 from 2003/9/27
    I would use a link to the image rather than trying to post it. I get a box with a red X in my IE (OS X)
    (red x with Windows XP IE also)
  • »14.10.03 - 05:07
    poundsmack
    ok go to www.themes.freshmeat.net and it is on the front page it is called "Elberg for IceWM 1.01"
  • »14.10.03 - 05:14
    Posts: 12442 from 2003/5/22
    It's kinda dumb to link to your local hard disk ;-P
  • »14.10.03 - 09:33
    I don't know where to get it, but it looks like someone took the default picture that comes with XP (green field) and cut off the sky and put a space background. I will try to see if I can find the picture though
  • »14.10.03 - 12:47
  • Targhan
    BMP, that explains a lot. Just for that, I'm changing all the images on MZ to ILBM!!!!!!
    Muhahahha!
    :idea:Targhan
  • »14.10.03 - 14:06
    No, that explains nothing :-P
  • »14.10.03 - 14:53
