Early release of AROS for EFIKA
  • ASiegel
    Posts: 1397 from 2003/2/15
    Michael Schulz writes on his blog:
    "Download this torrent, and test the AROS for efika yourself. It is not complete yet. You will surely see it crashing. The both IDE and network drivers are missnig. The release is unstable. Just put the ISO on CD, put it into your USB-CD or USB-DVD drive and start efika. Then, type following commands in the OF prompt:
    setenv boot-device cd
    boot cd os_image
    Once you see the Boot? > prompt, press 1 and be patient. The OF needs some time to read all aros' modules and will put enourmous amount of debug info. It will even report some missing file. Once AROS starts up, you will see the mouse pointer on the screen and CD drive working. Have fun. The serial port outputs debug information at 115200bps, 8N1.
    PS. My upstream is limited. Please seed the file after download."
  • »27.01.09 - 10:16
    xyphoid
    Posts: 870 from 2008/7/11
    got a page load error!
    nevermind...Iwas using firefox3 on macmini.
    Swithched to sputnik on efika and it came in
    reposted with sputnik
    [ Edited by xyphoid on 2009/1/27 18:21 ]
  • »27.01.09 - 20:37
    xyphoid
    OF stops after booting aros live cd at
    1. AROS for Efika 5200
    2. AROS for Efika Test 2
    nevermind again had the split screen going
    and didn't see the prompt and pressed 1 too late
    crazy boot sequence...now it stopped at
    Dev/ssfs.handleriso-9660 filesystem: system-id: "aros-ppc-chrp" volume-id
    Root dir: " " flags=0x2 extent=0x31 size=01800
    tried 3 times...no luck on this one
    [ Edited by xyphoid on 2009/1/28 2:00 ]
  • »28.01.09 - 04:36
    montymole
    Posts: 27 from 2008/10/23
    2nd version of the iso is still not working for me
    i get failed to load menu file from usb stick
    and the cd rom stops at ff95766c
    also had probs writing the iso on osx
    had to mount iso and copy files to burn folder then write the disk
  • »31.01.09 - 07:58
    skipp604
    Posts: 56 from 2003/8/21
    Seems like booting from usb stick is still impossible. As to the CD booting - you can't use HUB, you have to plug the USB->IDE adapter directly to Efika's USB port. These issuses will probably be addressed in the next release, Michal is working hard on them :)
    bplan Efika 5200B, ATi Radeon 9250 / 256 MB, MorphOS 2.4
  • »31.01.09 - 15:25
    xyphoid
    no go again. it stops booting somewhere during
    devs sequence.
  • »01.02.09 - 03:21
    montymole
    My hub's on efika usb 1
    and usb/ide is single on efika usb 2
    it is set and only works right set as slave!
    but doesnt power up power down constantly like if i set it to master as GEIT said to do
    so that's not why.....
  • »01.02.09 - 10:41
    montymole
    and usb/ide is all on its longsome on efika usb 2
    the cd it is set and only works right set as slave!
    so it is set by itself, so that's not why.....
  • »01.02.09 - 10:43
    Nitro
    Posts: 106 from 2003/8/24
    It stops for me at FF95766C
    looking forward to the next upload, thanks Michal.
  • »01.02.09 - 11:13
    xyphoid
    is there a way to maybe boot it from a partition. I dropped the iso into hd:2, but is there a OF command which may get it?
    I tried boot boot hd:2 load os_image
    it didn't go.
  • »01.02.09 - 14:13
    Chain-Q
    Posts: 350 from 2003/10/12
    Tried to boot it from a CF card in a cardreader (had no USB sticks or CD at hand) but no go. OF/SLB loads the files, then it stops booting. Haven't tried to hook it up on serial yet tho', to see what's wrong...
    [.Hosting AmigaSpirit.hu.]
  • »01.02.09 - 14:31
    skipp604
    Booting from onboard IDE, flashdisk, or through the USB hub is not supported yet. The hub issue will probably be fixed in the next release.
    Only way to boot right now is USB-IDE adapter connected to one of Efika's USB ports, with CD attached to it on the other end. This works for me, I booted AROS from CD several times already.
  • »01.02.09 - 14:53
  • ASiegel
    A new version has been released which is said to allow to boot AROS from USB flash drives.
    Download via torrent
  • »11.02.09 - 09:49
    montymole
    i thought this was the first release........
  • »11.02.09 - 12:28
  • ASiegel
    If anybody runs into problems, please comment on the developer's personal blog to make sure that he is aware of your experiences. He is looking for testers who are willing to send him detailed bug reports and debug logs.
    http://msaros.blogspot.com
  • »11.02.09 - 15:08
    skipp604
    The new version is really worth checking out!
    It finally boots from USB-Flashdisk (has to be formatted as SFS-RDB, though; there's still no full support for FAT-formatted ones).
    Booting time is still impressive on Efika's slow USB 1.1, but check it out for yourselves...
    And oh, write some feedback to the author, it's important! :)
  • »13.02.09 - 08:34
    jclausen
    Posts: 25 from 2004/4/17
    Dumb question I am sure...sorry, but:
    Does AROS on the EFIKA run Amiga 68K binaries?
    Thanks
    John
  • »13.02.09 - 21:12
    Posts: 12569 from 2003/5/22
    No, not in the sense MorphOS or OS4 run them. Else check out Janus-UAE project, which should also run on AROS for Efika once ready, albeit rather slow due to missing JIT.
  • »13.02.09 - 23:04
  • ASiegel
    Michal Schulz has released another test version of AROS for EFIKA which now includes the ability to install AROS to a harddisk. Booting via USB is no longer a requirement.
    The developer kindly asks for feedback from the EFIKA community who are willing to give it a try. Please post your comments to the developer's blog: http://msaros.blogspot.com/
    Download AROS for EFIKA: Torrent
  • »25.02.09 - 07:59
    Simon
    Posts: 809 from 2008/7/6
    Can I install it on my HD without messing up my MorphOS 2.x installation ?
  • »25.02.09 - 08:10
  • ASiegel
    Another release: LINK
  • »09.03.09 - 17:38
