New MorphOS User...
    pan1k
    Posts: 147 from 2009/1/20
    Just wanna say Hi! I have an Efika on the way. You guys might see me around as I configure my system. I'm just testing the Efika out, seeing if it's right for me. I've got a lot of experience with Amigas and a little bit of experience with MorphOS. See you guys around...
    Thanks Amigadave for getting me started!
    MacMini 1.5Ghz / Amiga 4000T Cyberstorm 060, 132MB RAM, Cybervision 64/3D, XSurf-III, MP3@64, Buddha Flash / Amiga 1200 GVP 030, Subway USB, 32MB RAM
  • »27.01.09 - 15:51
    Posts: 2217 from 2003/2/24
    Welcome! If you can tune AmigaOS, you can tune MorphOS :)
  • »27.01.09 - 16:01
    Posts: 80 from 2009/1/19
    Hello there, I just did what you are about to do!
    Things to look out for:
    1) get Radeon 1/2 height AGP video card.
    2) use FAT16 formatted USB drive that contains the efika install file. I had troubles with this initially but eventually conquered thanks to a lot of help from people here.
    I will be looking out for your future posts and will lend a hand should you need it.
    Good luck
  • »27.01.09 - 16:08
    pan1k
    All I know it's it's a Radeon 9200....Thanks for the tip on Fat16! I'm sure it will come in handy.. hehe
  • »27.01.09 - 16:49
    Posts: 1086 from 2003/3/24
    Welcome to the wonderfull land of MorphOS!!!
  • »27.01.09 - 17:23
