Weird network problem
    Motosampy
    Posts: 199 from 2004/8/14
    I'm experiencing weird networking problem. After using Linux (OpenSuse 11.0) on my PegII G3 I can't always access WAN before I go to System Prefs and change Static IP to DHCP... The weird thing is that I can access LAN without any problems. This problem has never occured with MOS 1.4.x, it started when I began testing 2.0 and still exists on 2.1 too.
    I have tried playing with DNS server addresses, I have tried using the viarhine-wakeup command, the only thing I still have not tested fully is the Gigabit ethernet port (will do that soon).
    Has anyone else had similar problem ?
  • »01.10.08 - 17:52
    HydroUK
    Posts: 7 from 2006/8/30
    Be sure to check your network configuration
    /etc/network/interfaces
    Make sure you have the static network defined or dhcp setup.
    Hope this helps!
  • »02.10.08 - 01:30
    Cego
    Posts: 733 from 2006/5/28
    play around with the loopback option, maybe it helps?
  • »02.10.08 - 01:44
