anybody wanna test this link?????
    klapdeur
    Posts: 132 from 2003/6/28
    Hi guys i was wondering if someone would test this link for me,
    i making a website on my amiga 4000 and want to know if its connected to the www outside my network.
    the link is: http://dennisbrink.dyndns.org/index.php
    Im building a forum on me apache server. just because its possible to do it.
    so if it works it would be fun to get new users, to test msql database is working and keep working.
    its my first time to work with mysql
    on amiga.
    its not to rip the community apart.
    Please reply on my forum or here.
    thnx in advanced
    Klapdeur
    [ Edited by klapdeur on 2008/9/14 14:10 ]
  • »14.09.08 - 10:50
    Posts: 1090 from 2004/9/23
    Seems to work!
    Geit
  • »14.09.08 - 11:09
    Posts: 2217 from 2003/2/24
    Looks OK, but feels bit slow.
  • »14.09.08 - 13:00
    klapdeur
    HI JpV
    well that it is a bit slow is that its running on my Amiga 4000, and
    im still working on it.
    Klapdeur
  • »14.09.08 - 13:14
    serge
    Posts: 725 from 2003/2/20
    It's working for me, but it's a bit slow.
    I tryed to sign in but cant see the confirmation code. there's no picture displayed.
  • »14.09.08 - 13:55
    klapdeur
    Hi serge
    about the register i had i yesterday to so i filled just something in.
    at the retry i did get the picture.
    i think it a bug or something.
    please try it again if you would.
    Regards
    Klapdeur
  • »14.09.08 - 14:01
    amiades
    Posts: 231 from 2005/6/2
    Seems to work quite well, but it's slow, indeed...
  • »14.09.08 - 14:47
    klapdeur
    Would anyone please wanna try to register , so i can see if mysql works properly.
    and if registration works.
    Regards
    Klapdeur
  • »14.09.08 - 15:13
    SoundSquare
    Posts: 1214 from 2004/12/1
    damn this "Amiga" logo isn't copyrighted ???
  • »14.09.08 - 18:23
    klapdeur
    Nope the amiga logo isnt copyrighted because its not the original logo.
    Klapdeur
  • »14.09.08 - 18:48
    klapdeur
    Klapdeur
  • »14.09.08 - 18:48
    pegasosuser
    Posts: 138 from 2004/4/9
    hallo klapdeur,
    het werkt goed de link ondanks dat het iets aan de trage kant is maar dat zal wel goed komen.
    groetjes Cor van Londen.
    PEGASOSII G4@1Ghz Registered MorphOS2.5 & AmigaOS4.1 1024DDRam ATI RADEON9250-256Mb(128Bit) Creatieve Soundblaster Live! 2 x HD MAXTOR U-ATA133 160Gb 8Mb-Cache Plextor DVDR +- RW 708A 2Mb Buffer ONLY PEGASOS MAKE IT POSSIBLE!
  • »15.09.08 - 12:16
    klapdeur
    Hi Cor.
    Leuk dat je bent gaan kijken.
    Dat hij wat traag is kan kloppen, hij loopt immers op mijn A4000 die host hem.
    Gr
    Klapdeur
  • »15.09.08 - 12:24
