Lucy, dont touch to my AmiStart please !
    serge
    Posts: 725 from 2003/2/20
    I indicated to Lucy to ignore one task like Elephant addind Elephant#? on the last option in Lucy's prefs. She understand very well my demand.
    Unfortunatly, when I do AmiStart#? , Lucy continues to blend it.
    I dont understand what is the diference between Elephant and Amistart to dont be managed by the same rules.
  • »12.09.08 - 18:31
    tokai
    Posts: 1289 from 2003/2/25
    Hmm... I wonder why Lucy messes with Elephant in the first place. It handles its Opacity etc. itself. Lucy shouldn't touch it then.
    Seems Gelb must improve his patch.
    Dunno about your AmiStart problem. Make sure you type the Taskname with proper case. Maybe it uses subtasks or something, try to find out proper name with TaskManager.
    [ Edited by tokai on 2008/9/12 22:20 ]
  • »12.09.08 - 19:19
    tokai
    btw... having the Task/Window ignore list in Lucy reversed... basically a Whitelist instead a Blacklist would make more sense. So you could have Lucy hacks for applications only where translucency remotely could make sense (AmIRC or so) rather than rendering the whole system to unusability by all the fading and blending. ;)
    Just a tip.
  • »12.09.08 - 19:28
    dIGIMAN
    Posts: 273 from 2005/11/7
    Just a tip.
    Yeah, a whitelist would make more sense, thats a good
    idea.
  • »12.09.08 - 20:49
