Mac emulation on MorphOS 2
    ausPPC
    Posts: 543 from 2007/8/6
    How system friendly were the various Mac emulators that run on Classic Amigas? Do they stand any chance of working on MorphOS's emulated 68k ?
  • »14.08.08 - 22:09
    Cego
    Posts: 738 from 2006/5/27
    the old mac emulators wont work on morphos due to the lack of mmu emualtion in trance.
    but there is a native port of basilisk for morphos.
    and btw, you can use OS 9 and OS X on the peg1 and 2.
    best regards
  • »14.08.08 - 23:01
    analogkid
    Posts: 722 from 2004/11/3
    As Cego said, you can use BasiliskII
    But for OS 9 or OSX, you have to use PegXMac or MOLK, which are based on Linux, no chance on MorphOS yet.
  • »15.08.08 - 02:52
    Jambalah
    Posts: 820 from 2008/3/30
    @ analogkid:
    link doesn't work. :-)
    Although the Aminet adress is right, when you click it doesn't work....
    Press here and scroll down... you will find it ;-)
    [ Edited by Jambalah on 2008/8/19 19:35 ]
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »19.08.08 - 16:30
    Posts: 12569 from 2003/5/22
    > link doesn't work.
    Reason.
  • »19.08.08 - 22:37
    zukow
    Posts: 662 from 2005/2/9
    no, mmu emulation is't required (ss/fusion runs on a1200@4mb without mmu/fpu)
    The problem is with first bytes of memory (allocated by prepareemul/rsrvcold) so boot.img should be compiled with support of it.
  • »22.08.08 - 10:46
