Quake3 with a Peg1 and a Radeon 9250AGP
    Charvel
    Posts: 97 from 2007/2/15
    Hello!
    I cant get Quake 3 to start anymore on my peg 1.
    Before it ran good with my AGP Radeon 7000 64MB, then I swiched to a
    9250 and it works in MorphOS but no games starts anymore.
    Cannot open screen it says.
    What can I do?
    [ Edited by Charvel on 2008/2/9 0:04 ]
  • »08.02.08 - 20:54
    analogkid
    Posts: 709 from 2004/11/3
    Did you install the second MorphOS 3D Update? The first one only supported TinyGL on 7x00 series on Peg1.
  • »09.02.08 - 05:01
    Charvel
    I dont think so.
    I cant find my serialnr for register MorphOS.
    And I belive that the FTP is the only place you could get it?
    How do I check witch version of MorphOS 3D Update and TinyGL I am running?
  • »09.02.08 - 09:22
    analogkid
    Yes, you are right, the MorphOS-Team FTP-Server is the place to find the update. I think you could check your version by querying the version-string of "MOSSYS:Libs/rave3d/r200.library". The first update has 51.10 (26.8.2005) of this lib, the second one has 51.11 (9.6.2006). For your serial-number you could send an email to the MorphOS-Team.
  • »10.02.08 - 04:45
    Charvel
    Thanks!
    I will do that :)
    I have found a 9100 which is even fassster than the 9250.
    [ Edited by Charvel on 2008/2/10 20:02 ]
  • »10.02.08 - 17:01
