Moderator
Posts: 441 from 2003/2/26
Hi
I'm also using samba (throw smb-handler) quite a
lot in my local network, and have small similar problems with it on the Pegasos. However I dont feel the problems are so very big, over all its working very well.
Amiganetfs is also working very good betweeen Amigas and the Pegasos. And so do Amtelnet for instance, and AmiFTPd as well.
Cheers
Gunne
Best wishes, Gunne
