mos 1.4 and JPG datatype
    serge
    Posts: 725 from 2003/2/20
    Hello,
    Since mos 1.4, my JPEG photos comming from my USB photo camera are no more reconized.
    Before 1.4, mysticview could see all my photos.
    Now, it tells me "unknow format".
    When I try to use one of them in ambient-Background, mos prefs tells me "file type unknow".
    All other jpeg files works fine.
    So is there something different betewen mos1.3 and 1.4 datatypes?
    Can I use other WARP datatypes?
  • »02.09.03 - 05:23
    Spidey
    Posts: 568 from 2003/2/24
    I'd say: just try it!! :-)
    Rename the datatypes in MOSSYS: and copy the datatypes you want to try into SYS:Classes/Datatypes and Devs:Datatypes.
    If it doesn't work...at least you've tried it :-)
    Good luck,
    Spidey
    ps: if you got it working, please tell us :-)
  • »02.09.03 - 18:01
  • HAK
    Posts: 227 from 2003/2/24
    @ serge,
    Hm, I just looked at it and the jfif.datatype of MOS1.3 and MOS1.4 are
    the same.
    However the picture.datatype has changed and the descriptor for JFIF
    also.
    Maybe this is the reason MOS1.4 does not recognize your pictures any
    more.
    If you have a photo which you dare to send me I would like to try them
    here - just for verification.
    Bye HAK
  • »02.09.03 - 20:52
    Bifford
    Posts: 283 from 2003/2/24
    Hi all,
    JPGs also dont work all the time here now either.
    If I load SGrab up and try to grab files as JPGs then it says "please install jpeg.library and restart SGrab" so something is obviously broken in the datatypes of 1.4
    TTFN
    Bifford
    Bifford the Youngest
  • »03.09.03 - 12:55
    Frostwork
    Posts: 302 from 2003/4/18
    Hi, serge!
    Strange....
    Did you try to boot from MOS1.4 CD and look if the
    jpgs work then?
    Here all jpgs (from USB-cam, too) work...
    Hi, Bifford!
    Yes, this is here the same. Grab PNGs and there are no problems....
    The only jpg.library I found is 6.2. And this one hangs
    here....
    So a question to people whose PerfectPaint works:
    Which jpeg.library do you have?
    bye
    frostjwork
  • »03.09.03 - 18:38
  • HAK
  • »03.09.03 - 21:06
    Frostwork
    Hi, HAK!
    Thank you!
    I had the WOS-jpg.library6.2 in LIBS:
    68020-version works with SGrab ;)
    Anyway I still grab PNGs....
    PerfectPaint anyway still refuses to work here....
    Doesn't even open its screen.....
    bye
    frostwork
  • »04.09.03 - 11:44
