Moderator
Posts: 2564 from 2003/2/24
If your really interested in running MOS on a budget you might start with a 2nd hand Pegasos-1. Just make sure it has atleast the April1-fix and known-to-work RAM included in the deal.
A new Efika might be (slightly) cheaper, but is also slower. For desktop-use even simple thinks like adding a CD-ROM or a USB2-card aren't really feasible (USB2-cards should work in Peg1, someone correct me if wrong). Don't forget that MOS isn't out for Efika yet, and while it might actually take only "1.5 weeks" it could just as much be 1.5 eternities
Don't get me wrong, the Efika can be a cute little toy, maybe even really usefull on some occasions (when it runs MOS that is), but I wouldn't even think about replacing my Peg with one (even if I only had the Peg1).
