IBrowse
    gunne
    Posts: 441 from 2003/2/25
    Best wishes, Gunne
  • »22.08.03 - 19:02
  • Targhan
    Posts: 2833 from 2003/2/7
    :lol: I know! There is a patch of some sort available (for MorphOS) to end this. But Ibrowse really thinks you are using OS4, and reports it as such.
    BTW: don't forget to include a topic! :-)
    :idea:Targhan
  • »22.08.03 - 19:16
    gunne
    Yeah, heard this about patch before... just did find it little funny when I noticed it now...
    Will try to remember this with topic :-D, little bit difficult to read else I saw...
    /Gunne
    Best wishes, Gunne
  • »22.08.03 - 19:31
  • Targhan
    :-) I'll see if I can find a patch, or if I can make one.
    :idea:Targhan
  • »22.08.03 - 19:40
    Piru
    Posts: 608 from 2003/2/24
    IBrowse-2.3-mos-1.4-verfix.pch readme
    To apply, you need the original IBrowse 2.3 executable, as "IBrowse-orig".
    spatch -oIBrowse -pIBrowse-2.3-mos-1.4-verfix.pch IBrowse-orig
  • »23.08.03 - 13:48
