Midi sequenser
    dolen
    Posts: 33 from 2005/10/16
    I had an idea to use the Efika as a midi sequenser. Its silent and small and with a small tft screen it would fit just fine on my yamaha S90 ES board. I hope it can be bought with a small case aswell.
    MorphOS boots up fast and I know the amiga system inside out. At least I did once. It?ll come back to me as I get going.
    So, is there any good reliable midi software on morphOS and are there any midi interfaces that work with the efika/morphOS combi?
  • »25.11.06 - 14:37
    hooligan
    Posts: 1948 from 2003/2/23
    There was a version of Bars and Pipes under work.. but in the end it turned out to be useless poc. The fact of the matter is that b&p was way too old to develope further. Would have been much better to just start a new sequencer.
  • »25.11.06 - 15:12
