AmiNetRadio - MIME-settings with Voyager?
    Henri
    Posts: 73 from 2003/5/14
    Hello folks,
    how should I set MIME, if I want to use
    Shoutcast-Playlists with Voyager/AmiNetRadio?
    With IBrowse it's no problem, but with Voyager it
    seems that I haven't set it right.
    Any hints?
    Regards
  • »16.08.03 - 09:23
  • Targhan
    Posts: 2833 from 2003/2/8
    Hello Henri,
    Several years ago, I wrote an amigaguide document on how to do just that for the UGN. Then it was put online at ugn.amiga.org. I don't know if they are still around, but you may want to do a search for "UGN Times" on Amiga.org.
    I believe the set up is simular, but the %f needs to be on the same line in Voyager.
    :idea:Targhan
  • »16.08.03 - 17:34
