HD data transfer
    Pearly
    Posts: 43 from 2005/6/8
    Hi
    I want to either remove my 60GB HD from from pc or transfer the data to my new computer . I'm thinking a Pegasos or Mac notebook.
    My question is which is easier removing the HD or transferring the data ...If I transfer , what is the safest way? If I remove the HD it may not work in a Peg ? ..and for sure it wouldn't fit in a Mac notebook. Anyone have suggestions ...*I'm not very computer literate . so I need an easy solution.
  • »23.05.06 - 22:20
    Pearly
    Hmmm ..no response to my questions , maybe I won't purchase a Pegasos then.
  • »24.05.06 - 14:07
    hooligan
    Posts: 1948 from 2003/2/23
    If the harddrive is partitioned as ntfs, there is a possibility to mount it on MorphOS using the NTFS-driver:
    http://www.aminet.net/search.php?query=ntfs
    If its FAT32, MountDOS will do the mounting for you:
    http://www.aminet.net/search.php?query=mountdos
  • »28.05.06 - 08:05
