My new iPod
    Posts: 1932 from 2003/10/19
    I just got a new iPod today! Its great, I had a older 20GB before, but now I got the video one. Its so cool. Very fun to use. Oh and mine is in a sexy black.
  • »29.10.05 - 03:15
    MarK
    Posts: 641 from 2004/1/25
    congratulations! and does it connect correctly as a massstorage device in morphos?
    bye, MarK.
  • »29.10.05 - 07:18
    maurensen
    Posts: 358 from 2003/10/3
    Yes, I've a 20gb Ipod Mini and it's recongized correctly as
    masstorage.device in MOS so I can use it as external HD.
    But to handle the playlists I'm forced to use GTKPOD under Linux
    because using ITunes under MOL doesn't work 'cause the USB 1.0
    controller in the Peg.
    Ola
  • »29.10.05 - 09:40
    deez
    Posts: 53 from 2003/5/28
    Did You try amiShuffle (dl from aminet) on MorphOS ?
  • »29.10.05 - 10:24
    Ola
    Yup if you format it to a Windows version and pug it in it works fine as a haed drive, I also used GTKPOD in Ubuntu linux. Cool think about connecting it to my linux on the Peg too is it will read all the songs on the iPod in hard drive mode and you can see the files. While on a Mac and PC they are hidden away.
  • »29.10.05 - 11:38
    maurensen
    mmmmh, thx Deez I never tried amishuffle before because I did't knew it before!
    I've dowloaded it right now and (after a backup of ipod database :-) I'll give it a try!
  • »30.10.05 - 14:05
    deez
    Maurensen, let me know when you check it.
  • »30.10.05 - 20:37
  • JKD
    JKD
    Posts: 456 from 2003/4/4
    Hey Paul...kick ass.
    I've had 3 generations of iPod now...currently 4th gen 60G iPod Photo....I will have to wait until thew 80G iPod with video appears though...my 60G is full to bursting with music + photos! :D
  • »01.11.05 - 05:12
    maurensen
    @Deez:
    No,amishuffle doesn't work here with my Peg. The playlist database format of my Ipod Mini is <> from the db format of the Shuffle...
    Lukily GTKPOD under Linux and my Peg with USB1.0 is faster and easier to use than ITunes in a gigaPentium with USB2.0!
    Olaz
  • »02.11.05 - 12:08
    Posts: 2095 from 2003/6/4
    I am happy my iRiver HP-120 is just usable under MOS as msd.
    If I'd buy a player now I'd go for an iAudio X-5:
    -very good sound
    -stylish
    -easy navigation
    -usb on the go
    -acts as msd.
    - fm tuner build in
  • »02.11.05 - 12:14
    deez
    @Maurensen:
    Hmm, then works ok only with IShuffle (on MorphOS of course).
  • »02.11.05 - 20:08
