looking glass live cd?
    DethKnight
    Posts: 139 from 2003/6/24
    things that make ya go "hmm"
    https://lg3d-livecd.dev.java.net/
    I am ; therefore you are
  • »25.10.05 - 16:25
    Posts: 1084 from 2003/3/24
    Does it work with Pegasos?
    Or is it x86 only?
  • »25.10.05 - 18:20
    DethKnight
    don't know, dont care, just happened to see the blurb
    on a different note, since ppczone.org is down for maintenance a t m, I shall post an interesting link
    http://www.arklinux.org/index.php?topic=release
    notice in upper right corner of page ....
    Sending us hardware - in particular, we're looking for a PowerPC based machine to port Ark Linux on
  • »25.10.05 - 19:54
    Frostwork
    Posts: 302 from 2003/4/18
    Hi!
    Not sure if I'm right, but i think it needs a newer version of Jave3D
    (1.4?), but PPC only has 1.2(or 1.3)...
    I tried to build an older snapshot & i failed...
    BTW does s.o. knows where full snapshots of newer sources can be
    found? (I don't have net at home & so no possib. to cvs or similar...)
    cheers
    frostwork
  • »27.10.05 - 08:54
