Do you use MorphOS to surf?
    analogkid
    Posts: 713 from 2004/11/3
    I mainly use IB on MorphOS for browsing, which is sufficient for most sites I visit, and if some pages don't work, I use Firefox on debian ppc
  • »08.09.05 - 11:10
    Brumiga
    Posts: 270 from 2004/4/3
    Hello,
    At home i only use IBrowse and Voyager. Sometimes i use AWeb 3.5.01 68k but it is slow, i have a 56k connection. When i will have a dsl connection i will try AWeb 3.5.05 for morphos.
    Brumiga
  • »08.09.05 - 11:43
    BigGun
    Posts: 150 from 2004/6/18
    Hi Brumiga,
    Especially for modem I would recommend the use of Aweb
    Aweb support some technics which will allow webpages to download _much_ faster.
    Many webpages download with Aweb 3.5.07 twice as fast as in Voyager adn Ibrowse.
    Ann.lu and Amigaworld.net are good examples of sites
    loading about twice as fast.
    Tryout Aweb 3.5.07 next week.
    Cheers
    Gunnar
    [ Edited by BigGun on 2005/9/9 14:17 ]
  • »09.09.05 - 10:14
    Brumiga
    Hello BigGun,
    Can you give me link to download AWeb 3.5.07 morphos ? Is this latest version stable or not ? I hope it is because i do not want to (beta)test it and encounter problems due to its possible beta state.
    Brumiga
  • »09.09.05 - 10:45
