Freespace and Heretic II and Shogo
    poundsmack
    Posts: 1346 from 2003/6/7
    do those game work on MorphOS?
    "Poundsmack, official morphzone thread creator" -LorD
    "Wanna be lord of the avatars." -JKD
  • »29.06.03 - 15:26
    serge
    Posts: 725 from 2003/2/20
    Heretic II and Shogo demo works fine here.( in software render. Would be better in hardware render ) ;-)
    Freespace works, but hangs in the firsts missions.
  • »29.06.03 - 16:05
    poundsmack
    sorry to sound uneducated but that is software and hardware render?
  • »29.06.03 - 16:40
    poundsmack
    will the games being released for AmigaOS4 be compatible with morphos?
  • »29.06.03 - 16:41
    Posts: 1077 from 2003/3/24
    No i don't think that this Games will run on MOS. I got Heretic2, Quake, Quake2 and Freespace running but have problems with Shogo won't start!
  • »29.06.03 - 17:16
    serge
    Software render is when all processing is done by the CPU.
    In software render, you need a very fast CPU to have a good rendering.
    Hardware render is when 3D procession is done by 3D chips on the graphic card.
    In Hardware render, a lot of work is done by the graphic card, then the cpu can do a lot of other things.
    In most of cases, in software rendering, there are a lot of Fx missing because they are very expensive in CPU time.
    is it clear now :-) ?
  • »29.06.03 - 19:19
    serge
    ThePlayer.
    Have you tryed to switch your graphic card to Big Endian mode by adding this tooltype on your icone GFX card ? RGB16BE=16.
    This will activate software rendering for shogo ;-)
  • »29.06.03 - 19:28
    Thanks for that hint i'll try it later when Shogo is back on my HD!
  • »30.06.03 - 14:57
    Henri
    Posts: 73 from 2003/5/14
    @ serge:
    Are You joking or what? :o)
    Regards
  • »01.07.03 - 10:34
    serge
    @ Henri
    what looks like a joke for you ?
  • »01.07.03 - 18:03
    Henri
    @ serge:
    I mean the RGB16BE=16-stuff, that he should set in his Gfx/mon.-driver
    Icon. I don't know such option for any Gfx/mon.-driver
    from MOS 1.3. I looked at the drivers and saw all options,
    but not this one.
    (What do You mean?)
    BTW: I tried Heretic-II-demo from AmiNet and if You set
    the software-render-mode in the config-file manually it runs.
    (config.cfg)
    Regards
    // Generated by Heretic 2, do not modify
    bind Tab "score"
    bind Enter "+defend"
    bind Escape "togglemenu"
    bind Space "+moveup"
    bind ' "+creep"
    bind + "sizeup"
    bind , "+moveleft"
    bind - "prev_class"
    bind . "+moveright"
    bind / "+moveup"
    bind 1 "use staff"
    bind 2 "use fball"
    bind 3 "use bloodfire"
    bind 4 "use plague"
    bind 5 "use rain"
    bind 6 "use fwall"
    bind 7 "use thunder"
    bind 8 "use sphere"
    bind 9 "use mace"
    bind Semicolon "+quickturn"
    bind = "next_class"
    bind [ "defprev"
    bind ] "defnext"
    bind ` "toggleconsole"
    bind a "+moveup"
    bind d "drop_item"
    bind e "use meteor"
    bind f "third0;echo First Person Mode"
    bind g "tog"
    bind h "hlp"
    bind i "+inventory"
    bind j "weapprev"
    bind k "drop_key"
    bind l "lift"
    bind m "+movedown"
    bind o "menu_objectives"
    bind p "menu_world_map"
    bind q "use powerup"
    bind r "third1;echo Third Person Mode"
    bind s "+back"
    bind t "messagemode2"
    bind u "menu_city_map"
    bind w "+forward"
    bind x "stat"
    bind y "use lshield"
    bind z "+movedown"
    bind ~ "toggleconsole"
    bind Backspace "score"
    bind UpArrow "+forward"
    bind DownArrow "+back"
    bind LeftArrow "+left"
    bind RightArrow "+right"
    bind Alt "+strafe"
    bind Ctrl "+movedown"
    bind Shift "+speed"
    bind F1 "taunt nonepass"
    bind F2 "taunt standaside"
    bind F3 "taunt scratch"
    bind F4 "taunt pansy"
    bind F5 "taunt noarms"
    bind F6 "taunt flwound"
    bind F7 "taunt chicken"
    bind F8 "taunt doyou"
    bind F9 "set cl_camera_dampfactor 0.2 ; set cl_camera_viewmax 200 ; echo Camera Normal"
    bind F10 "set cl_camera_dampfactor 0.0 ; set cl_camera_viewmax 1000 ; echo Camera Locked"
    bind F11 "menu_help"
    bind F12 "quit"
    bind Del "+lookup"
    bind PgDn "+lookdown"
    bind End "centerview"
    bind Kp_Ins "+klook"
    bind Mouse1 "+attack"
    bind Mouse2 "+defend"
    bind Mouse3 "+action"
    bind Joy1 "+movedown"
    bind Joy2 "+speed"
    bind Joy3 "+moveup"
    bind Joy4 "+attack"
    bind Aux5 "+movedown"
    bind Aux6 "+command"
    bind Pause "pause"
    bind_double DownArrow "+quickturn"
    bind_double Joy2 "weapprev"
    bind_double Aux5 "weapnext"
    bind_double Aux6 "+strafe"
    set snd_dll "ahisnd.dll"
    set allow_download "1"
    set allow_download_maps "1"
    set allow_download_players "1"
    set allow_download_models "1"
    set allow_download_sounds "1"
    set advancedstaff "1"
    set blood_level "2"
    set con_alpha "0.7"
    set ami_imagecache "2500000"
    set sw_allow_modex "1"
    set c_asm "0"
    set ami_dr_ratio "0.4"
    set dm_no_bodies "0"
    set cl_yawspeed "70"
    set no_middle_text "0"
    set shownames "1"
    set r_detail "2"
    set compass "0"
    set cl_camera_fpmode "0"
    set cl_camera_fptrans "0.0"
    set cl_camera_fpdist "1"
    set cl_camera_fpheight "0.0"
    set cl_playertrans "1.0"
    set playerdir "players"
    set autoweapon "1"
    set colour_obituary "1"
    set colour_chat "2"
    set colour_names "7"
    set colour_teamchat "3"
    set colour_level "16"
    set colour_game "3"
    set g_select_empty "0"
    set allowillegalskins "0"
    set log_file_name ""
    set log_file_footer ""
    set log_file_header ""
    set log_file_line_header ""
    set s_modeid "1179660"
    set ami_soundcache "1500000"
    set joy_up_reverse "0"
    set joy_forward_reverse "0"
    set joy_side_reverse "0"
    set vid_gamma "0.812500"
    set cl_run "1"
    set gl_driver0 "3DfxGL_Ht2"
    set hostname "McGregs"
    set sv_jumpcinematic "0"
    set sv_reconnect_limit "3"
    set vid_ref "soft"
    set vid_xpos "0"
    set vid_ypos "0"
    set vid_brightness "0.500000"
    set vid_contrast "0.500000"
    set win_noalttab "0"
    set vid_mode "3"
    set gl_ext_palettedtexture "1"
    set viewsize "100"
    set s_volume "0.800000"
    set s_sounddir "sound"
    set s_khz "22"
    set s_loadas8bit "0"
    set s_mixahead "0.2"
    set crosshair "1"
    set cd_nocd "1"
    set adr0 "24.9.52.241"
    set adr1 ""
    set adr2 ""
    set adr3 ""
    set adr4 ""
    set adr5 ""
    set adr6 ""
    set adr7 ""
    set adr8 ""
    set cl_stereo_separation "0.4"
    set freelook "1"
    set lookspring "0"
    set lookstrafe "0"
    set mouse_sensitivity_x "13.750000"
    set mouse_sensitivity_y "13.750000"
    set doubletap_speed "100"
    set m_pitch "0.022"
    set cl_camera_dampfactor "0.2"
    set name "McGreg"
    set skin "male/Corvus"
    set skindir "skins"
    set rate "3000"
    set msg "1"
    set fov "75.0"
    set sc_framerate "20.0"
    set in_mouse "1"
    set in_joystick "0"
    set file_gamemsg "gamemsg.txt"
    set file_levelmsg "levelmsg.txt"
    set cl_doautoaim "1"
    set pakfirst "0"
    set vid_fullscreen "1"
  • »01.07.03 - 19:37
    Henri
    Another hint for Freespace:
    If You have Frogger and want to look at smooth anims,
    download the latest PPC-Update from Hyperion and manually
    update the Freespace.prefs-file:
    [Caches]
    GfxCache = 31457280
    SoundCache = 6291456
    [Config]
    AHIFragmentSize = 2048
    AHIFrequency = 22050
    AHIUnit = 0
    Cd_Device = ide.device
    Cd_Unit = 1
    ComputerSpeed = 3
    ConnectionSpeed = Cable
    DisableMusic = 1
    DisableVoice = 1
    EnableAudioStreaming = 1
    FlightCenterX = 512
    FlightCenterY = 768
    FlightMaxX = 4096
    FlightMaxY = 4864
    FlightMinX = -512
    FlightMinY = -768
    FlightSwapAxis = 1
    FlightSwapDirection = 0
    Gamma = 1.80
    Language =
    LastPlayer =
    LowMem = 0
    NetworkConnection = None
    ScaleDownTextures = 0
    Soundcard = AHI
    Subspace = 1
    Videocard = Software
    VideoDir = YourPath:Freespace/data/Movies
    VideoPlayer = YourPath:FroggerNG/FroggerNG.MOS AUTOSTART AUTOEXIT FS
    DEPTH 24
    [MasterTracker]
    Login =
    Password =
    [Version]
    Build = 0
    Major = 1
    Minor = 6
    [Warp3D]
    CanBlendOneOne =
    CloseWorkbench = 0
    MinimumBitDepth = 16
    NoAlphaTexture =
    NoBlendOneOne =
    NoChromaTest = 1
    NoHidePointer = 0
    NumBuffers = 3
    RestrictTextureHeight = 256
    RestrictTextureWidth = 256
    TextureCacheSize = 16
    Windowed = 0
  • »01.07.03 - 19:43
