Lost Avatar
    Posts: 1084 from 2003/3/24
    Where is my avatar gone? After editing my Profile my avatar disappeard. And i can't upload my old one me very sad now :-(
  • »13.04.05 - 08:40
  • Targhan
    Posts: 2833 from 2003/2/7
    You are the second person that has run into this... Since we are on a temp server with lower bandwidth, uploading of avatars is turned OFF. Apparantly, when editing your own account (to change themes, your sig, whatever) the system wants to try to kick off your custom avatar (grrr).
    Be warned, do not edit your account if you do not want to use one of the stock 300+ avatars!
    Also, this is still *TEMPORARY*. Once we are back on the server we are supposed to be on, everything will return to normal.
    I am terribly sorry that this has occurred, but we should all be grateful that there was a backup server to even be on-regardless of restrictions!
    :idea:Targhan
  • »13.04.05 - 16:05
    Ok np, i think i can stick with the new one for a while.
  • »13.04.05 - 17:12
