Posts: 2727 from 2003/2/24
Miky060 wrote:
I only hope the 'new' MOS Team decides to release a complete update soon. Ambient 1.41 is out.
Note that if you want to continue using Ambient with "MorphOS 1.5" you would be better of to
downgrade to Ambient 1.4.0. But chances are that the next public release of the complete OS will come here in a form that is different than the "MorphOS 1.5" that has been showed on shows etc during the last year, so it may be that not even Ambient 1.4.0 will work properly at that time.
MOS1.5. kernel is out. new mui is almost out. Tprint fix is out, SDL libs are out togheter with a lot of other stuff.
The MOS1.5 kernel is *not* out AFAIK. There is obviously a difference between an unofficially leaked version that is still in development, and a version that has been freezed at a certain level to be included together with other freezed components in a complete OS release for end-users.
I hope they organize soon a new so awaited upgrade/package.
I hope they take the time needed to put together a real release, and not a mish-mash of half-finished components like some of the ones you are referring to (Ambient 1.4.1 for instance). In the mean time I would of course not mind to continue having these small releases of new or updated components!
MorphOS is Amiga
done right!
MorphOS NG will be AROS
done right!
