Posts: 2833 from 2003/2/8
OS4 screen hah
The only thing that could possibly be "os4-ish" would be the grey gradient, but that's just a darker version of the normal gradient.
I went ahead and fixed everyone's themes to the halloween one (you can change it back if you want.)
The time-out is 48 hours, and seems to work here. Unless you are using some kind of changing proxy or have a timed cookie remover on your system, you should be good.
@others
Thanks. Things will go back to normal on Nov 1, but I will keep this theme available as an option.
