Hi Serge.
You can print a web site with AWEB but not directly. you must save the page in ILBM and then print with Graphicpublisher. It's the best way.
When you can start Graphicpublisher...
Another solution :
-grab the screen
-install Linux
-copy the file in the Linux partition.
-start linux
-print the picture.
- you can also use a scanner, a printer, firewire extension with your Peg, but not with MOS...
