Woke up this morning...
    Toto
    Posts: 268 from 2003/4/20
    When I woke up this morning I noticed that my Peg II stopped working. It locked up earlier this morning, I could still hear the sound of my TV card. When I rebooted; nothing happened, the harddisks wouldn't spin on and no OF :-(
    Allready tried another PSU, removed several cards and used another videocard but still nothing. Guess I'll have to return my Peg to Computer City :-(
  • »10.07.04 - 08:51
    zacman
    Posts: 86 from 2003/2/26
    Have a look if the CPU card is correctly in the slot.
  • »10.07.04 - 09:01
    Toto
    Allready checked it, that's not it. Also when the ide cable is plugged in on the mainboard the drive's don't spin up but when the drive's are disconnected from the mainboard they spin up.
  • »10.07.04 - 09:04
    warface
    Posts: 653 from 2003/2/24
    If there is another computer in the household, try to check serialdebug.
  • »10.07.04 - 09:09
    Posts: 154 from 2003/4/22
    'lo
    some other options:
    - check in the heat sink is well monted on the CPU card. And that it covered all the CPU surface (not angle).
    - Look at the serial output, if you can. It usually gives some precious information.
    Bye
    MorphOS Rulez !
  • »10.07.04 - 09:11
    Posts: 1075 from 2003/3/24
    Do you run your Pegasos 24/7?
  • »10.07.04 - 09:37
    Toto
    No, normaly I turn off my Peg, but yesterday I was ripping a couple of dvd's on my windows box (wich I normally use to watch tv) that I'm gone use to veejay next weekend and I watched tv on my Peg.
    I'm gone get myself a serial cable and check the serial debug output. I also tried another memory stick but that wasn't it either.
  • »10.07.04 - 10:17
    catohagen
    Posts: 297 from 2003/5/20
    Man, that sucks....guess the warranty will cover this, you shouldn't send your pegasos back for repair, a good service would be Genesi send you a new pegasos and you send your old one back when you have your system up and running.
  • »10.07.04 - 12:09
    Toto
    Yeah it sucks big time. I bought my Peg at Computer City and they have a good service. I'll send it back monday and hopefully I'll have it back next weekend. Oh well, back to my A4k wich until now never quits on me ;-)
    Went shopping for a null modem cable but unfortunally the shops I tried didn't have it. Tommorrow I'm gone build one myself.
  • »10.07.04 - 12:24
    Posts: 1932 from 2003/10/19
    That sucks real bad! I keep my Pegasos II G4 on 24/7 is that bad? I've done that will all my computers as long as I can remember.
  • »10.07.04 - 13:07
    Before sending the mobo back to Computer City, you should check what's going on the Serial port with your 4K.
    You can use DraemTerm (Aminet) for that: 115200 bauds.
    You will certainly get some information.
    My computers are powered on most of the time too. However, I do recommend to use a UPS and a reliable PSU. A lot of computer crash (Pegasos or not) are cause by bad electricity.
    You can find a cheap UPS for less than 100 Euros. It's really worth if your computer is running all the time. Also, do not choice the cheapest power supply.
    <SOME AD>
    I personnaly use an "APC Back Ups 500VA BK500EI" bough there: http://www.aps.fr/?category=19.
    </SOME AD>
    And no problem.
    Bye
    Let's hope it's noting.
    MorphOS Rulez !
  • »10.07.04 - 13:55
    Posts: 261 from 2003/3/13
    Welcome to my world..
    I send my system about a month ago to CC,
    my G4 card died.
    CC (Ron) is currently on vacation,
    he will be back in a few weeks.
    Hope they can fix it soon.. I'm getting
    very depressed working with windows on
    my laptop :-)
  • »10.07.04 - 14:21
    Robin
    Posts: 741 from 2003/2/24
    :-( You scare me ...
    I've put my own G4 (passively cooled by Zalman NB Cooler)
    into a Desktop with a low power psu (200W) so there is near
    to no airflow in the case ...
    Runs since a week 24/7 ...
  • »10.07.04 - 14:49
    Toto
    @NicoPPC
    I made a serial null modem cable and installed DreamTerm on my Amiga 4K, the only output I got on my Amiga is a character when I turn the Pegasos on and a character when I turn the Peg off. Do I need to change other settings in DreamTeam or is changing the baudrate enough?
  • »10.07.04 - 17:06
    Posts: 2727 from 2003/2/24
    No, of course not! :-)
    I have had my Peg2 G4 running 24/7 at 100% CPU since early March, crunching RC5 keys (I only turned it off just the other day to make some re-arrangements of my "machine park"). It's made for using! :-)
    But everything can brake down, and everything DO brake, eventually ...
  • »10.07.04 - 18:08
