Divinity schrieb:
I don't know if you can set up Internet sharing, but if all you need to do is transfer Amiga files (downloaded from MorphOS via Wi-Fi) over Ethernet, I don't think you'll have any trouble setting up an Ethernet connection between the two computers (using a different subnet class than the Wi-Fi router and not entering any gateway or DNS addresses), setting up a simple FTP server on one of the computers and an FTP client on the other
Yes, thats exact what i want. Download over MorphOS by WiFi and send over to the direct connected Amiga 500. Thank you, i will test it, if i can get this to run.
Amiga 500 Rev. 6a, DF1: Gotek, ACA500plus, X-Surf-500, ACA1234+RTC-Modul, Indivision ECS V4, Picasso96, AmigaOS 3.2.3
Mac mini G4 (Late 2005, 1,5 GHz, 1GB Ram), MorphOS 3.20 (reg.)
