MorphOS 3.20
    Tcheko
    Posts: 543 from 2003/2/25
    NewSense wrote:
    @ geit - I'm back, but you'll find out soon (via email in detail) that . . .
    Sadly, you were wrong . . . It is v3.20 for iMac G5 A1145 [mine]/ A1144 [untested/not owned] (It's a FAIL)  :-(
    Someone (or maybe even sometwo or more) in the MorphOS Development Team did not do their homework correctly for the iMac hardware that you support . . .
    Yada yada. Beware of backfire...
    NewSense wrote:
    As it locks up the whole system on a vanilla install on my iMac A1145 when you load any MP3 file into Jukebox from a playlist.  :-(
    Mind sharing the playlist somewhere? The explosion you have is either:
    - a MP3 making demuxer/decoder exploding
    - some content in the playlist is incorrecly parsed by Jukebox
    In both case, there should be no crash. Provide playlist for a start. And find the potential MP3 doing nasty things inside decoder/demuxer. Dichotomic algorithm is probably the way to go. Divide the playlist in two parts, load parts. If it breaks again, divide the offending playlist in two, repeat until you have a handful of MP3 in. Should be pretty quick to pinpoint the MP3 triggering doomday.
  • »09.06.26 - 17:09
    NewSense
    Posts: 1597 from 2012/11/9
    @ Tcheko - I have basically got the same advice from jacadcaps as to me checking through the files to establish where the error is.  ;-)
    Jacek is assisting me with identifying where this "bug" is - which does indeed totally "freeze" my system within about 5-8 seconds of starting to load the MP3 files even if I load it via the MorphOSBoot CD (which cannot be any more "vanilla" if I tried) running them in the latest version of Jukebox in v3.20 with the MP3 files I have always referred to in this thread.
    These files run without issue in Jukebox in v3.19 or any other prior version of MorphOS that I have tried them with over the years prior to v3.19. It is only v3.20's release that is causing this issue, and as I have said that includes running it from the MorphOSboot CD, so MOSSYS / Jukebox in v3.20 is doing something that it doesn't do with any other release!
    If I replace only the MOSSYS of v3.20 with the MOSSYS of v3.19 all works without issue, and I can even use the release of Jukebox that comes with v3.20 with the v3.19 MOSSYS without any problem, but it "freezes" with v3.20, it is as simple as that, and I have spoken with cyfm on the topic briefly though I know he is not currently available for more detailed assistance right now, but he has offered his assistance when he becomes available again, as he too, like jacadcaps, owns an iMac A1145 which is the system that is manifesting this "bug" with my hardware.  8-)
    Though thanks for your interest, and suggestions as to how to resolve the issue.  8-D
    MacMini 1.5GHz,64MB VRAM, PowerBooks A1138/9 (Model 5,8/9),PowerMac G5 2.3GHz(DP), iMac A1145 2.1GHz 20", all with MorphOS v3.19+,Airport,Bluetooth,A1016 Keyboard,T-RB22 Mouse,DVD-RW-DL,MiniMax,Firewire/USB2 & MacOSX 10.4/5
  • »10.06.26 - 00:00
    Tcheko
    NewSense wrote:
    ... bla bla bla...
    Did you do the dichotomic search for the offending MP3 breaking the system?
    Where is the playlist?
    If you don't give us what's needed to reproduce your case, we won't be able to fix anything. Case closed for me as you're likely not willing to provide the requested information.
  • »10.06.26 - 06:40
    NewSense
    @ Tcheko - that is entirely not the case, and I more than willing to agree to assist, ideally just jacadcaps at this stage. My delay in replying is due to having been engaged elsewhere, with other issues - as life, and all that goes with it, does need attending to from time to time as well! ;-)
    I said I was going to pass my findings back to jacadcaps, but the Playlist as such is a whole directory of MP3s, WAVs, AACs, etc. and it is 11.3GB in size (not the playlist but the directory, so passing you all the files details would take up a large amount of space on here, and so sending whatever details jacadcaps needs by email seems a better solution for me. If he then decides to pass any of that information on to you then by all means he has my agreement to do so, at this stage, but I am going through the directories basically as advised to identify at which point the system freezes. Hold on, with a bit of patience, and I feel sure I will get to the point where you as a developer needs to be to asses the impact of this "bug" to fix it.  8-)
    Thanks for your interest in this issue.  8-D
    [UPDATE] - I have forwarded my checks loosely based on the "dichotomic search" and some of the audio files in my music library to jacadcaps, with what seems to be conclusive as to the cause of the "freeze". I believe I "short-circuited" this search by just loading a wide variety of varying filetypes and this brought about an almost immediate "freeze". So, as you have shown interest (Tcheko) I will send you a PM with some of that information, so you can get as involved as you want to, and maybe get in direct contact with jacadcaps for any additional details you feel you need to know, and once again thanks for obvious interest in resolving this issue that has affected my iMac with this outage. 8-D
  • »10.06.26 - 09:50
    Tcheko
    Amazing. Instead of saying straight that you're in fact loading a directory full of various audio file formats, you tell us that you're loading a playlist of MP3...
    I feel exhausted.
  • »10.06.26 - 12:27
    NewSense
    @ Tcheko - if only my way of wording loading those music files tires you out, then go and have a lie down, though doing that bit of sideways thinking doesn't really justify being exhausted, does it?!  :-?
    Go and have an energy drink or a banana or something to top up your energy levels:-?  8-D
  • »10.06.26 - 14:39
    Posts: 1088 from 2004/9/23
    It is about you presenting your evidence. Pages long mail and posts alternating giving little information each time.
    I first had the impression for several days that any file is causing the JukeBox crash, then you gave Jaca the information about loading a playlist with 12K files and now it is not even a playlist, but a folder with music files you opened.
    You should really work on the form you present stuff. If your goal is to piss off every MorphOS developer you are on a good way.
    I alone got several mails with several bloated pages of text, where you failed to provide any useful information beside some breadcrumbs hidden in gigantic text blocks, where you are waffling around on the same facts over and over that you found out and where we where wrong.
    And stop using all the text style changes. It is annoying.
    However, credits to jPV, he found out that .ogg files are the problem and delivered two files causing trouble, so the bug could be isolated and fixed. This is how it works.
    [ Edited by geit 10.06.2026 - 22:30 ]
  • »10.06.26 - 15:48
    NewSense
    I seem to remember you saying, Quote:
    geit wrote, ". . . As I said by installing the Crysalidis your system is no longer supported." and . . . "You are on your own now, since this is the second issue caused by Crysalidis, which you installed and we (The MorphOS Team) have no control of."
    How many users over the years installed the Chrysalis Pack of software to enhance their base setup? So, how many other MorphOS users should your comments to me also apply to? You would probably only have 25%, or less, of the registered users left if you went that route!
    In any case, I had no idea that some of the files were going to get placed incorrectly, or where they actually got placed, and I suspect many other users, as novices, as I was back in 2012, would have been, and may still be, in the same position. There was no information available that some files were known to have been installed incorrectly, and which files they were, so that they could and should be removed. My system, when you identified this as a potential problem to the stability of my system was taken very seriously by me, and I removed those files from my system very quickly.
    As it turned out those errant Chrysalis Pack files had not caused this problem, they were basically "dormant", but I am grateful that you identified them to me, as it has allowed me to remove them so my system is more likely to be inline with a standard MorphOS system, with the system directories only containing the files they should.
    I still consider that it was somewhat extreme of you to say to me those comments that you made, while not even considering that my comments were factually correct . . . as it is something in v3.20 that was the cause of this "freeze". As you completely ignored my factually correct assessment, and became "blinkered" in focusing on the issue as being the Chrysalis Pack's residual files that were the cause of the "freeze" . . . that was incorrect, and from my standpoint poorly considered as you never looked into my report at all AFAIK.
    You ended up blaming me, and basically shunning me (your comments above speak directly of that), for identifying an issue that v3.20 has become wrongly endowed with, while failing to check out the report, or ask me for more details that would have correctly identified this issue, much sooner. Do you think that all other users that installed the Chrysalis Pack should also be "shunned"?
    I agree with you, Quote:
    geit wrote: It is not the job of the MorphOS Team to fix systems the user messed up in the first place.
    However, there should be some guidance as to how to fix them ideally, if the user has made that "mess" inadvertently and installed some software "in good faith" that it would not cause such a problem. After all the overall stability of users' systems is also in the best interests of the MorphOS Development Team, so there are fewer or no false reports of issues. I did not need much help to realise what had been left on my system, after your guidance, and my system has been "exorcised" of those files now.
    I have said it before, for me, the Chrysalis Pack was a quick way to enhance the MorphOS system, but I did not realise that some files, and software might be potentially errant or harmful, as the Pack had been around for quite a few years, with no mention that I came across, back in 2012, that stated it was, "install it at your own risk, and you are now excommunicated from support from MorphOS!"
    Surely there is no need for such vehement comments now. I have identified the problem as not being mine, but something in v3.20, that ideally should not have slipped through the betatesting, though we are all human, and anyone, even a very experienced beta testing team can inadvertently allow the occasional error, or mistake in their oversight to occur, if I have identified the situation correctly.
    geit wrote: Maybe it is time to learn yourself how to fix issues you caused by not following instructions yourself, instead of demanding, yelling and crying around that the MorphOS Team changed something that caused issues. I wonder who fixes your Windows, Linux oder MacOS systems and whom you make responsible for errors on those systems.
    For my part, I never demanded, yelled, cried that the MorphOS Team had changed something. I tried to explain what I had encountered, but found you focused on the Chrysalis Pack's potential for creating trouble for the MorphOS system, by overriding features and files that were intended to keep the system stable. I accept that the Chrysalis Pack had issues, but they were known to you in the MOS Dev. Team, not really to me as a novice user in 2012, and no-one from the team spoke to me about the potetntial issues it might cause back in 2012, or at any time since then up until this current date, and I did not see any forum threads, certainly not active ones, that identified such issues.
    With regard to my own non-MorphOS system, it is me that maintains them, like I removed the errant Chrysalis Pack files. It is always beneficial to have guidance from an expert such as you, which I appreciate, though you, sadly, probably don't believe me.
    I did say in a previous thread that . . . Quote:
    NewSense wrote: Bear in mind that just swapping out the MOSSYS directory for the previous installation has resolved the issue with Jukebox, so surely it is something that is causing the issue within that directory (MOSSYS), or some file that Jukebox needs - within 15 seconds of being started that is the trigger for this severe incompatibility.
    Your reply, and I cringe (wished that you had not said them) at the words you used Quote:
    geit wrote: No it is not! That is what you think. I already explained that in another post above. You are on your own now, since this is the second issue caused by Crysalidis, which you installed and we (The MorphOS Team) have no control of.
    You offered no support, for what has turned out to be a valid issue it seems, and all you offered was no future support, as a result of installing the Chrysalis Pack that I installed "in good faith" back in 2012 - 14years ago, with no adverse system errors that directed me back to ask for support during that time, apart from to ask recently about LoView and now v3.20's "freeze"!
    geit wrote; Crysalidis is nice to find out what is possible on a fresh MorphOS install. You should install the software by yourself and use something less invasiv like Easy2Install and cherry pick the software you really need instead of dumping the entire MorphOS files onto your harddrive.
    It is all very well saying that in 2026, but in 2012 the Chrysalis Pack was basically all there was, apart from Grunch that offered some update(s). Whereas the Chrysalis Pack offered enhancements that included additional skins, pointers, wallpaper, icon packs, default icons, utilities, tools, programs (applications), etc., all of which together were too tempting to ignore when initially starting out with MorphOS for me.
    Why doesn't the MorphOS Development Team, knowing that there is probably a demand for such additional customisations, make an "authorised" pack available for new and established users to enhance their systems, knowing that the files that are going to be added to a system are then not going to adversely affect the stability of its system, yet allow users to modify, and customise their systems correctly, in keeping with MorphOS's system structure?
    Many users took up using MorphOS as an alternative to OS4 that had failed to deliver IMHO, whereas MorphOS had faster hardware, was easier to acquire, and cheaper to afford, with many pieces of Apple G4 and G5 hardware available to choose from, easily the BEST Amiga-like Next Generation system available, and still is IMHO.
    geit wrote: It is about you presenting your evidence. Pages long mail and posts alternating giving little information each time.
    I seem to remember that I was trying to convince you that it was an issue in v3.20 . . . not the Chrysalis Packs remnant files that were still on my system, but you did not seem to want to know that it was a MorphOS issue!
    geit wrote: I first had the impression for several days that any file is causing the JukeBox crash, then you gave Jaca the information about loading a playlist with 12K files and now it is not even a playlist, but a folder with music files you opened.
    You did not reply in this thread for over 2 days, and I never got a reply back from you about any of the details I passed you, so how would I know what the "impression" was that you had formed. You have to communicate, and ask questions if I have not explained something sufficiently to you, to find out what I had observed, rather than "shun" me by telling me I am "now on your own", for an incorrect judgement you made, and wrongly accused me of afflicting my system as a result of installing the Chrysalis Pack in 2012!
    geit wrote: You should really work on the form you present stuff. If your goal is to piss off every MorphOS developer you are on a good way.
    I tried to get you to see that it was not the Chrysalis Pack that was the issue, but that it was MorphOS v3.20's release that had the issue that was causing my system to "freeze", but as then, as your above comments bear out, and even now you are not really acknowledging that v3.20 is where the issue resides. You only needed to reply to me with specific questions as to what I had observed in as much detail as I could offer, and I would have elaborated where necessary.
    What is the difference between a PlayList, and a List that you Play? I added the files to Jukebox to play, and it made a list! There is little difference between the two methods of getting some music files to play, it is a moot point IMHO. However, if you had decided that it was a MorphOS v3.20 issue, instead of focusing on it being a Chrysalis Pack issue, then you could have, and should have, focused on that, and checked out my observations, that I reported to you in "good faith" in a timely manner, and asked me any questions that would have assisted you in detemining where the problem lay, but I feel certain your focus was on it not being a MorphOS v3.20 problem and merely the Chrysalis Pack's, and my own as a "dumb" user's, fault!
    geit wrote: I alone got several mails with several bloated pages of text, where you failed to provide any useful information beside some breadcrumbs hidden in gigantic text blocks, where you are waffling around on the same facts over and over that you found out and where we where wrong.
    . . . That you never got back to me about their content, to ask any relevant questions to isolate the information you needed to know. No communication, no further explanation!
    I would have hoped that this "bickering" would not have occurred, or that you would not have intimated that I was now to be "shunned" for adding the Chrysalis Pack onto my system, over 14 years ago, in "good faith". That seems to me to be where you focused your thoughts and comments, as the Chrysalis Pack only being the issue that had caused this "freeze".
    For my own part I had no intention for this back and forth of unnecessary comments to happen, or by anyone else in this thread. I had only the intention to pass back that I had come across a problem with v3.20 and it caused my system to "freeze" and for it to be taken on-board seriously, but it was not, and no amount of complaining about long emails that you never replied to can fix a problem that you failed to grasp as a MorphOS issue . . . which it is!
    geit wrote: And stop using all the text style changes. It is annoying.
    Yes it is!  8-D
  • »10.06.26 - 22:45
    Piru
    Posts: 617 from 2003/2/24
    There is a bug in MorphOS Reggae Ogg Vorbis demuxer (ogg.demuxer). Unfortunately the nature of the bug is that any Ogg Vorbis file with negative stream serial number being processed by Reggae will cause a hard crash. ogginfo tool (part of vorbis-tools) can be used to identify the files that cause the crash. For example on a linux system, to check all .ogg files in current directory that will cause issues:
    ogginfo *.ogg | grep -B2 "serial: [89abcdef]"
    If you absolutely cannot risk a crash we recommend deleting ogg.demuxer from 3.20 install with:
    delete MOSSYS:Classes/Multimedia/ogg.demuxer
    This will effectively disable the broken Ogg Vorbis support and prevent a system crash.
    A proper fix to this issue will be released as part of MorphOS 3.21. Special thanks to jPV for the delivering sample files demonstrating the problem.
    [ Edited by Piru 11.06.2026 - 01:24 ]
  • »10.06.26 - 23:09
    NewSense
    Hi Piru - thanks for confirming the "freeze"/crash" that seems to be the same that my system encounters, which is what I had been trying to get taken "on-board" by the MOS Dev. Team over the last few days, but had only established myself that it related (I assumed) due to an .ogg file being loaded, probably only partially, as it "froze" as it loaded the file it seemed to me.
    However, I assume it affects all hardware for MorphOS, not just my iMac A1145 G5? As it seems that you consider it to be a system wide issue, as you state that the Ogg Vorbis implementation in MorphOS v3.20 is now considered currently broken!
    Which is what I was kind-of expecting was going to be the outcome due to my system's "freezes".
  • »11.06.26 - 03:30
    Posts: 2212 from 2003/2/24
    Jukebox allows you to save and load special playlist files, so when talking about playlists the program author may easily think you're loading these kind of files instead of adding new audio files on the program. Adding new audio files on the program is basically creating a new playlist from the scratch, so yeah... this is why it's important to describe your actions as precise as possible when reporting a bug, because people start thinking the issue from a different angle.
    Yes, I was able to reproduce it on a Mac mini, for example.
  • »11.06.26 - 04:15
    Posts: 12530 from 2003/5/22
    > active ones, that identified such issues. [...] It is all very well
    I remember that also here on MorphZone, some MorphOS team members (especially geit and Krashan) have rather outspokenly discouraged MorphOS users from installing the Chrysalis Pack (or Ultimate Pack as it was called until 2013) from early on for the potential issues it might cause, recommending Grunch instead.
    Playlists are specific files that can come in several file formats, meaning that any player program malfunctions may be caused by a malformatted/corrupted playlist file when the program's playlist interpreter lacks robustness in that regard. If you directly add audio files to Jukebox, the list it creates is internal instead of a possibly broken external file.
  • »11.06.26 - 06:34
    Posts: 81 from 2020/5/1
    My ethernet interface is not working since upgrading 3.18 to 3.20 on my Sam460ex. How do I reset all network settings?
    Unit is N/A under Network unit statistics. Changing from DHCP to static and vice versa doesn't help. The interface is ppc4xx_eth.device:0, version 50.7 from 24.12.2020
    According to release notes lot's of stuff have changed:
    Prefs/Network
    Show current IP address next to the IP field, if found
    Check if interface is configured before querying it
    Added MUIA_Prefs_ActivePage supportPrefs/Network
    Net/Netstack
    Improved to work past year 2038
    Fixed sendmsg()/recvmsg() to not tamper with user provided array
    Fixed memory corruption issue with QUERY HOSTNAME arexx command if no hostname has been set
    Improved Berkeley Packet Filter compatibility
    Improved resource leaks in some error code paths
    Disabled TCP/IP stack hacks & features that are long gone and might actually harm connectivity
    Improved argument checking and validation
    Fixed user interface hiding on exit
    Fixed network stack statistics
    [ Edited by duga 11.06.2026 - 13:52 ]
  • »11.06.26 - 12:51
    Posts: 2090 from 2003/6/4
    jacadcaps schrieb:
    @NewSense
    Just tried Jukebox / MP3 on my own iMac and it plays just fine. Not sure what you mean by vanilla install? Did you wipe your HDD?
    Either way, randomly dumping issues in this thread isn't getting anything resolved. Everyone, please use the report bug functionality, one report for one problem, including as much detail as you can. This ensures we can track things.
    @Zylesea
    Sent you a link to a debug-enabled Wayfarer to try and track this down (using the email address in your profile)
    Sorry for late answer, days were pretty busy. Here's the log:
    34443.398| == Info: timeout on name lookup is not supported
    34443.410| == Info: Host morphos-team.net:443 was resolved.
    34443.410| == Info: IPv4: 65.109.53.106
    34443.410| == Info: Trying 65.109.53.106:443...
    34443.412| == Info: timeout on name lookup is not supported
    34443.458| == Info: Host wayfarer.icu:443 was resolved.
    34443.458| == Info: IPv4: 95.216.45.180
    34443.458| == Info: Trying 95.216.45.180:443...
    34443.465| == Info: Cipher selection: TLS_CHACHA20_POLY1305_SHA256:TLS_AES_128_GCM_SHA256:TLS_AES_256_GCM_SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES128-SHA:ECDHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA:AES256-SHA
    34443.465| == Info: TLS 1.3 cipher selection: TLS_CHACHA20_POLY1305_SHA256:TLS_AES_128_GCM_SHA256:TLS_AES_256_GCM_SHA384
    34443.465| == Info: SSL Trust Anchors:
    34443.530| == Info: CAfile: MOSSYS:Data/SSL/curl-ca-bundle.crt
    34443.530| == Info: ALPN: curl offers h2,http/1.1
    34443.531| == Info: TLSv1.3 (OUT), TLS handshake, Client hello (1):
    34443.533| == Info: Cipher selection: TLS_CHACHA20_POLY1305_SHA256:TLS_AES_128_GCM_SHA256:TLS_AES_256_GCM_SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES128-SHA:ECDHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA:AES256-SHA
    34443.533| == Info: TLS 1.3 cipher selection: TLS_CHACHA20_POLY1305_SHA256:TLS_AES_128_GCM_SHA256:TLS_AES_256_GCM_SHA384
    34443.533| == Info: ALPN: curl offers h2,http/1.1
    34443.535| == Info: TLSv1.3 (OUT), TLS handshake, Client hello (1):
    34473.399| == Info: Connection timed out after 30001 milliseconds
    34473.399| == Info: closing connection #0
    34473.414| == Info: Connection timed out after 30001 milliseconds
    34473.414| == Info: closing connection #1
  • »11.06.26 - 20:53
    Posts: 3296 from 2003/3/5
    @Zylesea
    This looks like TLS 1.3 is failing for you entirely. It may be that your networking equipment or your internet provider drops the required packets. If you have some linux box on the same network, see if
    openssl s_client -tls1_3 -connect wayfarer.icu:443
    connects OK.
  • »12.06.26 - 10:55
    jacadcaps schrieb:
    @Zylesea
    connects OK.
    It seems something is really the issue with my network account or router. If I connect a MorphOS machine via a mobile hotspot it works. This post is typed with Wayfarer 11.3 from the 3.20 release connected via hotspot of my Sailfish phone.
    I guess I have to inestigate further what's wrong with my network - am now on a local network carrier (Bitel) on DSL via a Fritzbox7490, but that will change any day to glass fiber which is in the house already and I am just waiting to get switched. Hopefully issues wlll be gone then.
    A word to my mobile(Sailfish: As Sailfish is a Linux I first tried the suggested openssl connection test with that, but this thing hasn't openssl on board (or is somewhere hidden, terminal says "openssl: not found") and I am a bit too much of a noob regarding Sailfish/Linux and failed to install openssl on that device quickly... My sailfish experience may sound a bit off topic, but is an actual praising of MorphOS. Of course it's not a straight comparison (phone vs. desktop), but all in all MorphOS is more polished than Sailfish is and has a way better browser (the sailfish standard browser is way beyond). Of course Sailfish is a Linux and you can do quite a lot with te according knowledge and get the sources and packages somehow, but that is not too user friendy. And the preinstalled apps or the app stores are rather beyomd the MorphOS coverage. And that for a Linux OS vs. a super duper niche non-ix OS like MorphOS.
    We really have a gem here thanks to many good and productive developers and a constructive community.
    [ Editiert durch Zylesea 13.06.2026 - 20:19 ]
  • »13.06.26 - 18:58
    Fritzbox is not the issue, but my carrier Bitel is: testing dss.bitel.net on ssllabs.com says it does not support TLS1.3.
    Gosh!
  • »13.06.26 - 19:16
    Piru
    @Zylesia
    ssllabs test saying that company site doesn't support TLS 1.3 is unrelated.
    However, it appears that some network equipment causes the connectivity issues for you when TLS 1.3 connections are attempted. This is rare these days, but not unheard of. This could for example be active TLS inspection to identify which host is about to be connected to prevent user from accidentally connecting to malicious sites. Some equipment like this only works with up to TLS 1.2 and completely rejects connections with TLS protocol versions that they do not support.
    This might even be the FritzBox itself. FritzBox 7490 has a feature called "Parental Control" that inspects the TLS traffic and attempts to block malicious sites etc. https://assets.avm.de/files/docs/fritzbox/fritzbox-7490/fritzbox-7490_man_en_GB.pdf
    It might be worth checking if the router is running the latest firmware version and try updating to latest, if not. If it still fails with latest firmware then you could try disabling the web filtering if it is enabled.
  • »13.06.26 - 22:03
    Piru schrieb:
    @Zylesia
    Messed up the testing of a server's services with the carrier's service... it sounded so fitting ;-)
    But indeed disabling a blocking list on the fritzbox resolved the issue. Disabled all filters for my MorphOS machines now on the Fritzbox. This is now typed on Wayfarer 11.3 via my home WLAN.
    Thanks for the hints and help - I would not have solved that by myself.
  • »14.06.26 - 10:26
    I wonder what you set-up that cause that issue. Using a 7490 without any issues.
  • »14.06.26 - 12:33
    Try either copying the eth device or netconfig.library from 3.18 and report back. Would help to know which one it is.
  • »14.06.26 - 17:09
    Nothing special:
    internet -> filter
    Filter für Internetseiten
    Hier können Sie festlegen, ob und welche Internetseiten für dieses Zugangsprofil gefiltert werden.
    (x) Internetseiten filtern
    Filterlisten
    ( )Internetseiten erlauben (Liste anzeigen)
    Nur die Internet-Adressen, die in der Liste enthalten sind, können aufgerufen werden.
    (x) Internetseiten sperren (Liste anzeigen)
    Alle Internet-Adressen, die in der Liste enthalten sind, sind gesperrt.
    Aufrufe über IP-Adressen sind ebenfalls gesperrt. (Ausnahmen anzeigen)
    (x) jugendgefährdende Internetseiten sperren(BPjM-Modul)
    Zusätzlich werden die von der Bundeszentrale für Kinder- und Jugendmedienschutz (BzKJ) indizierten Internetseiten gefiltert.
    Hinweis:
    Die Filterlisten können Sie im Bereich "Internet > Filter > Listen" lesen und bearbeiten.
    Now I just disabled all filters for the MorphOS machines in the network, while the kid's devices + TV still get restricted access. Works for now. At least as long as my kids don't demand MorphOS machines for themselves which of course I would like, but they are just bound to Apple kit thanks to their schools...
  • »14.06.26 - 17:47
    ppc4xx_eth.device is the same in 3.18 and 3.20 (same version number 50.7 and same size).
    Replacing ­netconfig.library version 51.15 (size 29484) with 51.14 (size 29383) solved the problem!
  • »15.06.26 - 13:04
    @duga
    Sent you an email with a debug-enabled version of that library and instructions. Hopefully we can figure this out.
  • »15.06.26 - 14:45
    Divinity
    Posts: 506 from 2009/9/8
    Kronos wrote:
    Well release notes for Radeon and TinyGL don't mention 3D support for these, that should give you the answer.
    For the moment a x1950 is best option for anything 3D, and it can even handle 2 screens with 2560x1440 pixels at over 50Hz.
    You can even get 3440x1440 or 4k working if your monitor syncs down to 40Hz.
    hi guys,
    I plan to use my dual-core PowerMac G5 with an ATI Radeon X1950 Pro PCIe graphics card with a nice 30" Apple Cinema Display via dual-link DVI.
    Since I have to drive several kilometers to pick it up, am I sure I’ll be able to get the most out of it in MorphOS at a resolution of 2560x1600 via dual-link DVI? (both the display and the graphics card are dual-link).
    Of course, I’m also interested in using it at other video resolutions such as 1280x1080, 1024x768, 800x600, and 640x480 ... especially for gaming.
    Below are the specifications for the 30" Apple Cinema DVI dual-link display https://support.apple.com/it-it/112528
    I think this is a great solution, but before I go pick it up since I’ll have to drive several kilometers I’d like to get your confirmation.
    Thanks
  • »19.06.26 - 12:24
