transparency Ambient feature
    sergius
    Posts: 47 from 2005/12/6
    Il like a lot the transparency Ambient feature, but I feel it is strange to have one opaque window and all others on the back transparent. All those transparent windows make for me a visual confusion. I was wondering if it's possible to parameter it differently.
    I would like to have a transparent window only for the window moving during the move. Then releasing it, the windows become opaque again.
    Thank you in advance for your help.
  • »19.04.26 - 13:30
    Posts: 607 from 2003/4/11
    You can adjust that feature in system prefs in the DisplayEngine Effects Tab. It won't work for moving a window, though. It is only meant for a solid active vs. non opaque inactive windows.
  • »19.04.26 - 14:51
    Tomtom76
    Posts: 43 from 2021/6/26
    I got it on my MacOS 9 installation. It calls Power Windows and combined with Platinum Sounds it's really cool feature. Unfortunately not available on MorphOS AFAIK.
    Powerbook G4 A1106 MorphOS 3.19 & MacOSX 10.4
  • »19.04.26 - 15:50
    Posts: 3300 from 2003/3/5
    This is not a bad idea, actually...
  • »24.04.26 - 15:45
