Posts: 2220 from 2003/2/24
When right-clicking the icon file in the List mode, you get the same context menu as you'd right-clicked on the window title bar, any other columns in the list view, or any other "empty" area of the window. This lets you to do window related operations like changing the view mode etc.. Filetype related context menu opens only when you right-click the filename, so it's consistent in that regard. I don't see any issues in this.
Edit: or if you're nitpicking, maybe icon column should also open the filetype specific context menu, because in the icon mode it does that when clicking on an icon.. you don't have to click on the name then. But generally speaking, only the name column opens the filetype specific menu in the list mode, which has been the easiest solution by coding I guess :)
[ Edited by jPV 11.05.2025 - 02:02 ]
