Posts: 1609 from 2012/11/9
Kronos wrote: Radeon card needs to either have a PPC OF which is pretty rare as PCIe and would negate the need for the NVidia card.
So, which
Radeon PPC PCIe G5 PPC cards are there to choose/find that will work straight out-of-the-box (OOTB), even if it doesn't come with a box
Quote:Kronos wrote: Or AtomBIOS which came out later. What you want is something RadeonHDxxxx (look
here ).
I know that the Radeon X1950 card is very popular for this model of PowerMac G5 (A1117/A1177) but that card is not a RadeonHDxxxx card anyway, so what makes that work even though it's not an HD model Radeon GFX card?
Also, the same goes for the other cards in the "X" list ... X600 XT (R380), X800 XT / Pro (R420), X1300 or Pro, X1550, X1600 or Pro, X1800, X1900 GT, X1950 XT or Pro, or FireGL X3 (R420) - what makes those work in the PCIe G5 PowerMacs or are some/all of them also AGP card variants as well?
Also, how many Radeon HDxxxx cards have been tested in these systems as it seems it might be almost hit or miss if you get a card that will work, and I don't want to end up buying cards that don't work time after time and get nowhere, as that then would make these cards and this project more costly.
Kronos wrote: You may also want to double check with what is supported in the last tinygl beta.
I'll do that, thanks for mentioning that.
Kronos wrote: Also, try booting by holding "Alt" as "C" might fail.
OK I'll probably try both keys to see what does and doesn't work - once I find a GFX card that has an Atom BIOS in it, ...
by the way ... how do I do that, check that it has an Atom BIOS, as I can't see which chip on such a board is the Atom BIOS, and handily this feature does not seem to be specified in any of the card specs that I've checked through so far, or are ALL the HD models Atom BIOS based?
Kronos wrote: The GPU in an iMac surely comes with a BIOS compatible with the OpenFirmware used in that iMac.
koszer wrote: You're obviously and painfully right.
So, theoretically it would be possible to dump the compatible ROM from an iMac G5 X600 and then flash NewSense's PC BIOS card with it.
That's a great idea, if only I was capable of carrying out such a procedure, and had the hardware and software to be able to do so!
However, I would try to do that if I got sufficient guidance as to how to accomplish that.:-)
Kronos wrote: Of course there are numerous issues that might arise (first one that comes to my mind would be the capacity of the ROM chip on PC version of this card). From what I remember the Radeon 9600 was also quite a hit-and-miss when it comes to successful flashing the AGP versions. But it doesn't hurt to try, right?
Kronos and
Koszer - thanks for your replies so far, much appreciated.
If I knew how to flash the BIOS on the PC card, or got the required guidance, etc., then I'd try that as surely using an Apple PPC BIOS would be preferable as then I could use the Radeon to gain access to Open Firmware as well, and would not need the NVIDIA in the system at all, which might also liberate others from this need to keep their NVIDIA card in their system, and more of us would have access to and the ability to amend the OF much more easily!
