MorphOS Developer
Posts: 3278 from 2003/3/5
Try fixing your partition with SFSDoctor (assuming it is SFS-formatted). It's in Tools.
My other ptoblem is that I cannot create partitions and later they didn't appear on Ambient.
You likely did not format them. You can do this from Ambient's menu Utilities -> Format Disk.
