Low-level format
    Sukkulento
    Posts: 40 from 2004/4/6
    What can I do for low-level format my HD (not from GUI)?
    Is it possible on PegII? It is not Implemented yet on Open firmware?
    Bye
    sukkulento
  • »19.04.04 - 16:07
    Spidey
    Posts: 568 from 2003/2/24
    Hello Sukkulento,
    Congrats with your first post here on MorphZone :-)
    I tries it once, but to my knowledge it's not possible with the Peg to lowlevel format.
    Do you have an Amiga? Perhaps you can try it with that?
    Bye,
    Spidey
  • »20.04.04 - 05:59
    Sukkulento
    thanks, Spidey
    Is not possible? I have PegII -G3.
    oK, I must put HD in my old computer, and low-level formatting by AMI-Bios.....
    It' incredible....
    Sukkulento
  • »20.04.04 - 12:42
    Jupp3
    Posts: 1193 from 2003/2/24
    May I ask why you need to low level format it?
    No "new" hard disks should be low level formatted afaik...
    ("new" as in "manufactured within 10 years", I guess)
  • »27.04.04 - 18:38
    ultraspec
    Posts: 94 from 2004/1/29
    Jupp3 is right.
  • »28.04.04 - 18:19
